Results 1 to 3 of 3
Thread: brake light bulbs
    1998 VS Ute
    Jul 2010
    Perth Hills
    Default brake light bulbs
    hey guys, got clear aftermarket tail lights on my vs ute ( don't laugh ) and the right hand brake light doesnt work but the drive light does, assume its just the filament of the stop light that's blown, which means replacing the bulb, when i went into malZ to get a new bulb the dude asked whether or not the pins on the bulb are offset or normal? anyone know? fairly sure its the stock socket that the bulbs sit in so if someone can tell me whether the bulb is offset or normal, apparently something to do with the length of the pins. He also said that you cant get red bulbs with the normal pins and that i'd have to dye them red myself.. bullshit or not? cheers in advance
    Making a 4 cylinder fast is like telling everyone your gay. At first you might suprise a few people but in the end, you're still a fag.
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    Pull the globe out, if the pins are directly opposite then they are normal, however if on one side of the bulb the pin is closer then it is on the other side it's offset? Catch my drift lol. And yeah if you have clear tailights then im pretty sure you will need red globes, otherwise when you turn on your lights/brake it will just be white/yellow. They guy is on the money though. If in doubt just take your globe into them and they will have no worries matching it up
    VS 5 Litre BT1
    Jul 2006
    Yeah, just take the existing globe in and find one with the same part no.
  1. VT interior Light bulbs?
    By gru53m in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-05-2010, 04:01 PM
  2. How do you change fog light bulbs?
    By cjw.891 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-03-2010, 09:02 AM
  3. VE fog light bulbs
    By tomholzy in forum VE Holden Commodore (2006 - ?)
    Last Post: 01-09-2009, 08:17 PM
  4. Fog Light Bulbs
    By MickVE in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-08-2009, 09:05 AM
  5. Light bulbs
    By LYRIC in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-08-2005, 09:17 PM
