Results 1 to 9 of 9
Thread: clanging sound after changing steering rack
    VR S
    Sep 2007
    Default clanging sound after changing steering rack
    ok first post i replaced my steering rack a couple of days ago ever since had this clanging sound on the left side when turning left, since then i have removed the front strut and tightened everything up again new front struts and springs are fine only 4 months old all new bushes radius rod control arm yada yada tried skinny tire on front to make sure it wasnt tyre scrubbing strut checked rack and pinon nuts and bolts all good please help going nutz .... also just had wheel alignment done
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    VR S
    Sep 2007
    yeah rack seems good no leaks no float handles fine turns both left and right with ease just this clanging sound high pitch the heavier the turn, doesnt effect steering what so ever but loud enough that a defect would get slapped on it
    VR S
    Sep 2007
    has anyone else had this problem or heard of it could it possibly be a rack end? it was running fine in a vs drove it to my place vr and vs are the same rack, same rack ends arent they
    VE S2 SV6/A6
    Apr 2011
    Can you get the car on a hoist and see what happens when there is no weight?
    This Might point to a rack issue rather than components clashing when weighted
    Current Ride: 2011 VE Sedan - In Voodoo of course.
    Last Ride: 2004 Subaru Liberty GT, Twin scroll turbo, tuned, Bilsteins, sway bars, no rice, 420Nm
    Also Own: 1964 EH Wagon, modified interior, minor modifications outside
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I'd say it is the swaybar link bushes.
    Visit my Facebook page
    VR S
    Sep 2007
    cheers for replies but....... sway bar links replaced with suspension 4 months ago all front bushes replaced with nolethane with the exception of the inner control arm bushes got told to go pedders rubber so did, car jacked up wheels turn left and right lock 2 lock no noise and same distance perfectly. inspected all bushes links pins everything is better than good but still have this problem i mean the car drives sweet just the horrible obvious noise when i turn left and cant affort a defect. any other ideas could it be an internal problem in the rack or rack end but 2 do only one side ? im going nuts trying to figure this out
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Are the nuts tight on the link pins? The washers can jingle.
    VR S
    Sep 2007
    yep done tight everythings done up sweet ill change the rack back to the leaky old crappy one tommorow, and maybe that will stop it, can't see how but has to be the rack. its a recon but everything else has been checked and re-cheeked if its the rack i feel sorry for the place i got it from as they do the work there im gonna rip them a new 1. ill post my findings cheers!
  1. Swap variable speed steering rack for regular rack?
    By _R_J_K_ in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-04-2010, 08:06 PM
  2. Engin Light Problems And Clanging sound.Help
    By MechanicFreak in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-11-2009, 04:07 PM
  3. Changing VL rack ends
    By Morton in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-01-2009, 01:39 PM
  4. VH steering rack
    By wickedVH in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-10-2008, 11:25 AM
  5. oil line from power steering to steering rack
    By onmy6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-12-2007, 10:08 AM
