Results 1 to 13 of 13
Thread: How easy is this to fix?
    Vx Series II R8 Clubsport Build 295
    Apr 2009
    Perth, WA
    Default How easy is this to fix?
    Long story short, some hot little P plater chick decided to reverse into my car in Northbridge one Friday night. Only at about 5kms/ph
    Insurance Quotes $2,400 for repairs
    while i have the pay out im not going to spend that much on a car that's only worth 3,500
    so the plan was to fix the front end myself and prep it for a respray.
    the only problem is i have never adjusted these panels on a commodore before. From what i can tell the front Side panel has slightly twisted. making nothing line up
    cheers
    Attached Thumbnails Attached Thumbnails How easy is this to fix?-29042011-003-.jpg   How easy is this to fix?-29042011-005-.jpg   How easy is this to fix?-29042011.jpg   How easy is this to fix?-29042011-001-.jpg   How easy is this to fix?-29042011-002-.jpg   How easy is this to fix?-29042011-004-.jpg
    LS1 Owners Club
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    looks like its just come away from the clip. Try and line it up and then give it a good bash with you're hand. If not take it off and see what damage is done.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    Apr 2009
    Perth, WA
    i think your right there about the bumper. but that still dosent solve the bonnet being so out of line
    LS1 Owners Club
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    check the bolts on the bonnet hinges, mightve been enough force to shift the bonnet on the hinges
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    Are you referring to it being out of line between the quarters? As it looks about the right space. The front bumper will need to come off in order to take off you're headlight.
    VS Acclaim
    Jan 2010
    Looks like what happened to mine last week.
    The metal backing plate that the front bumber is attached to has moved. I found that the supports that hold it in place had bent. I took off the front bumber, heated up the support with a blow torch and hit it back straight with a hammer. Not perfect but alot better than what it was. Not really noticable unless you look for it.
    You will also need to take the bumber off to replace your headlight.
    Was a good 3hrs work by the time i had finished. Not overly hard, just a pain to get the front bumper off initially.
    As for the hood im not too sure.
    I replaced the headlights in my car with strobe lights, so it looks like I'm the only one moving
    VS Berlina
    Mar 2011
    Woodford QLD
    zapper-l67's Avatar
    zapper-l67 is offline LS# Eat One Today...
    VX Calais
    Jan 2010
    Western Vic
    Yer tell her its going to cost at least one date, and maybe a few more depending on just how upset you are..
    This is the sort of stuff that happens when the kids get into Dads tool box over weekend.
    Money will be spent, Dreams will be shattered, Lessons will be learned, and a wealth of information will be gained.
    Apr 2009
    Perth, WA
    hahaha yeah i do have her number i think after a 900 dollar excess she wont wana talk much though
    and yes your right the brackets behind the bumper have bent and the bonnet has moved down and to the right on its mounts.
    ive tried for a few hours and could not get the bonnet to line up, maybe the drivers quarter panel is bent?
    LS1 Owners Club
    VS S-Pack SII
    May 2008
    am i missing something here.... SHE reversed into you... and YOU are paying for it???
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by PanthaVS View Post
    First post by the OP says: "while i have the pay out im not going to spend that much on a car that's only worth 3,500" ....so I'd guess he has been paid already.
    I don't think this chick is the first person to misjudge when reversing........................
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    $2500 for repairs I dont think so,a new bonnet and head light might cost you $500 then fit it yourself
    VS S-Pack SII
    May 2008
    Quote Originally Posted by hako View Post
    ahhh my bad.... i misread it... speed reading, i read it as " while i have to pay out" ....
    allll good!
  1. NEED HELP! maybe be easy fix maybe not.
    By esca_ByDesign in forum General
    Last Post: 28-01-2011, 06:10 PM
  2. Easy Outs = Fkn not so easy...
    By Mirkz in forum General
    Last Post: 30-12-2010, 09:54 PM
  3. easy rwc
    By MUNTED6 in forum General
    Last Post: 09-08-2010, 08:26 PM
