Results 1 to 12 of 12
Thread: Water pump Leaking
    vr commodore
    May 2009
    Default Water pump Leaking
    Hi Guys just noticed over the holidays that my car is leaking coolant, its at the stage that i have to fill the radiator every morning.It only needs about 1/2 a litre of water, when i searched for the leak it looked to be leaking from behind the harmonic balancer but after having a better look at it tonight it appears to be leaking from a gasket above it (is this the water pump ). Now the car drives fine no overheating the temp gauge rises up to halfway etc if i get stuck at the lights but then go's back to normal after.Ive checked the radiator upon arriving at home and the radiator will be low but not bone dry. Now does this sound like the water pump (i dont even no where it is situated, a friend told me it is likely it) and is it still safe to drive till it gets fixed and what sort of $$$ will it cost. Thanks for your advice..
    vr94ss's Avatar
    vr94ss is offline walks barefoot
    VR SS '94
    Feb 2009
    Lismore, NSW
    The water pump has a drain hole that let's water out in case the seal goes bad so the water doesn't destroy the bearings. You can use a small mirror to see. The water usually runs down the pump and from there down the front of the motor to behind the harmonic balancer. It may be safe to get to somewhere to fix or last months just topping up, but I would fix it ASAP. Cost? Dunno.. V6 or V8?
    VR S
    Sep 2007
    sounds like ur water pump not to difficult nor expensive ring around or get a mate to do it i think i paid about 70 bucks for mine and took me about 30- 40 minutes to do behind the harmonic balancer black thing in the middle sorta shaped like a boat
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    Quote Originally Posted by brianbee View Post
    i put a new water pump on my old v6 ute.....2days later leaking again??? took it to a mate and he took out the water pump bolts and gave the threads a good clean,put em back on and 2 weeks later it was leaking again......3rd and last time he put some kind of sealent on the bolt threads and it never leaked again....
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Could also be the timing cover, I've had one corrode where the water bores are and it looks like it's the water pump leaking. Water pump has to come off either way so remove that first then have a look.
    This was on a v6.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    Mar 2008
    might as well replace your coolant as well if it hasnt been done lately and your thermostat
    i always clean the threads up before i put the bolts back in and normally smear a small amount of grease on them to stop them rusting in there
    a water pump for a v6 should cost no more than $50 - $70
    put some sealant around the gasket as well
    make sure before you take the drive belt off you loosen the bolts holding your water pump pulley on first
    vs wagon
    Apr 2011
    new zealand
    my water pump went, the leak was visable from the drain hole as vr94ss said, easy to fix takes very little time 5 bolts from memory and under $100.
    vr commodore
    May 2009
    Thanks for the advice guys, i dont think im to mechanically minded to fix it myself have it booked in this week at the mechanics to get fixed ..Thanks
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    It could also be the thermostat housing gasket and the thermostat, I thought it was the water pump in my car but it turned out to be the thermostat gasket because the thermostat wasnt opening up.Bloody hell how many times did I write thermostat in this post.
    Sep 2005
    are you in melb??? i can point you towards a good cheap holden mech if you down in melb.............
    vr commodore
    May 2009
    No i live in adelaide. Where abouts is the thermostat situated, ill have a look at it, looked at another thread on changing the water pump and may try changing it myself. Is there anything i should be wary of, do the bolts need to be torqued and how hard is putting the belt on. I am barely a novice at anything mechanically as i say i dont even know where the thermostat is located..
    Hangman's Avatar
    Jan 2010
    Where the top radiator hose joins the top of the motor is your thermostat housing. Thermostat lives under it.
  1. vrvs sedan water found in boot how i tested to find where the water was leaking from
    By peter1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-01-2011, 08:49 PM
  2. water pump hose leaking?
    By vncruzr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-04-2009, 10:46 PM
  3. water pump leaking
    By darno in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-03-2009, 07:42 PM
  4. Water pump leaking? 97VT
    By Wong in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-02-2008, 08:29 PM
  5. leaking water pump?
    By VNexecutive in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-02-2008, 08:00 PM
