Results 1 to 3 of 3
Thread: VS starter noise
    vs wagon
    Apr 2011
    new zealand
    Default VS starter noise
    Hi hope someone can help diagnose a problem.
    I have a vs v6 auto. starts fine but sounds as if the strater is still engaged, the noise doesn't change with the revs.
    have tried turning off the car and restarting, no change, only thing i did find is when i drove it 800m up the road (i knew better) it was very hard to start again till it cooled off
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The only thing you can do is lift the bonnet and listen close to the starter when the engine is idling...it will sound pretty loud. I had this happen on an XF Falcon...drove about 500m till car died due to starter finally shorting internally and causing a dead short on the battery which killed both battery and starter motor.
    It may just be loose bolts connecting the starter to the engine or the solenoid sticking...no matter what, I'd fix it pronto before it costs big $$$$.
    Good Luck.
  1. Noise that i thought was pulley noise can't be ??????
    By chris oo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-03-2011, 05:10 PM
  2. starter motor noise
    By randallbass in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-06-2010, 05:06 PM
  3. FRONT WHEEL Brake NOISE - me and my mechanic cant find source of noise. help???????
    By northqueenslandvs97 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-05-2010, 08:36 PM
  4. AC Noise in Cabin - High Pitch Noise
    By yor71 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-05-2009, 05:47 PM
  5. Replies: 3
    Last Post: 09-09-2005, 11:11 PM
