Hi All,
I have just replaced the TPS on my 95 VS Commodore. I have checked the fault codes after installing and it says everything is fine (fault code 12). But the engine is now spluttering and reving really high. I did remove the engine fuse for about 5 minutes to reset the computer but it still is playing up. Any ideas?
Did you check the fault codes after you started getting the spluttering and engine revving really high? Did you replace the drive adapter?
Reset the IAC? 3k RPM for 15 seconds from memory.
it's all good, sorted it out with the help of a friend. Thanks guys.
What was the problem?
