Results 1 to 4 of 4
Thread: VS Getrag Manual Lumpy Clutch
    VS V6 Commodore series 2
    Mar 2010
    Default VS Getrag Manual Lumpy Clutch
    gday just wondering why my clutch is so lumpy or what-not.
    can just feel the clutch vibrating and lump around.
    wondering if its doing any damage to the clutch itself or do any damage in the future?
    car was converted from auto a month or 2 ago.
    thanks
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Is it at idle or when on the go or when it depressed on let off, did you machine the fly wheel and use a new clutch and pressure plate is there grease or dirt on it?
    Lots of different problems a bit more info would help.
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    As above, when exactly is this happening? Were new parts used?
    The getrag flywheel is dual mass and cannot be machined. Did you check how much free play rotation it had when it was installed? With the flywheel bolted to the crank, off the top of my head the service limit is 10mm of circumference rotation.
    Mar 2010
    umm sometimes it does it some times it doesnt. usually when down gearing ill notice it the most
    new clutch kit. and the free play rotation was 18mm. we were told the limit is 20. whats so bad if its over 20? does it do any damage? or malfunction?
    thanks for the hlep guys
  1. GETRAG 5 speed manual help...
    By bozza91 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-05-2010, 09:23 PM
  2. Strange getrag/ t5 clutch?? Help
    By speco in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-01-2010, 08:27 PM
  3. [NSW] Exedy HD Clutch kit V6 Getrag Solid flywheel
    By Swordsy in forum Parts And Other Items For Sale
    Last Post: 14-09-2009, 04:17 PM
  4. Getrag Clutch
    By VS Ute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2008, 10:56 PM
Tags for this Thread
