Results 1 to 8 of 8
Thread: Need help asap
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    Default Need help asap
    Ok guys im stuck ive got a vr acclaim with irs, the auto is not working to well, You put it drive and struggles to bearly move, unless you put in into 3rd then drive and so on, Ok so if i put it in any gear except 1st or 2nd (always been this way since ive had it) it will squat...Reverse is fine, My old xf done this with my 5 speed and it was the diff, What do you guys thinks
    05 vz ss
    Oct 2010
    brisbane
    under the fascia off the centre console there is a little halfa circle module there it tells the transmison to change gears when you select gears .my suspison is that needs to be replaced mate
    05 vz ss
    Oct 2010
    brisbane
    Vr acclaim
    Jun 2010
    Vr acclaim
    Jun 2010
    also thought id mention that the other day it decided to run properly but not shift to good and now ts stopped does that sound like the sensor
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    Vr acclaim
    Jun 2010
    Ok so i change the sensor and now it sounds like its got a transbrake engaged, But it is alot better then it was perhaps torque converter? if so are vs ones the same?
    vs caprice
    Dec 2010
    brisbane
    Quote Originally Posted by vs2DSIRE View Post
    that is the neutral cut out switch lol 2 wires for starting 2 wires for the reverse lights
  1. Need help asap!
    By richardbignutsonstato in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-08-2009, 02:22 PM
  2. Anyone with a 308 help ASAP PLEASE
    By gupatrol in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-03-2008, 12:07 PM
  3. help plz asap
    By iRiot in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-01-2008, 02:16 PM
  4. help asap
    By silver88vl in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-04-2007, 12:31 PM
  5. Need Help Asap
    By commo69 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-03-2007, 02:49 PM
