Results 1 to 16 of 16
Thread: jerky acceleration when i put my foot down
    VS Exec S2 bt1 1996
    Apr 2011
    sydney
    Default jerky acceleration when i put my foot down
    i have a V6 VSs2 1996 and when i put my foot down the excelleration is jerky. any ideas what this could be?
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    VS Exec S2 bt1 1996
    Apr 2011
    sydney
    the only thing ive tryed so far is injector cleaner but no different.so you suggest to try changing the leads and ignition?
    VS Exec S2 bt1 1996
    Apr 2011
    sydney
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Is it on LPG?
    If not, do your leads and plugs.
    Visit my Facebook page
    VS Exec S2 bt1 1996
    Apr 2011
    sydney
    scottcalais369852147 is offline cruizincalais
    vp calais
    Dec 2006
    coils, i had the same problem, i changed the coils, leads and plugs, now no problem
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    Quote Originally Posted by comfortablynumb View Post
    good starting point is>>>>>>>>> change the coils, leads and plugs
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    vs wagon
    Apr 2011
    new zealand
    to save buying a new coil pack test them with an ohm meter, they should all read very similar. clean/gap your plugs and then throw some new leads at it. if it is constantly 1 cylinder down it could be the module block. all easy fixes, just try the cheapest ones first
    Holden Commodore S Supercharged 3.8L
    Mar 2012
    Adelaide Australia
    hey, I've got a VT Supercharged V6 , and every time i put my foot down and rev it up to 60+ it won't go you feel the car jerking up and forth.... they say its the fuel pump... I'm not sure if its the leads and coils.. does anyone know ?
    Cheers,
    few commodores
    Feb 2011
    victoria
    check for codes, if none present.......
    start with the basics, plugs, leads, air filter, fuel filter, tps, then work up to the big expensive parts, fuel pump, cas, dfi module, afm
    If it doesn't move, force it. If it breaks it needed replacing anyway.
    '94 VR Exec
    Feb 2010
    Wagga Wagga, NSW
    When was the last time your fuel filter was changed?
    WTB: VR/VS S/SS Lower front bumper lip/spoiler
    VS Commodore 3.8L
    Feb 2010
    had the exact same problem for the last 2 or so months
    changed the leads and plugs. nothing
    changed the fuel filter. nothing
    changed the dfi module and coil packs. worked!!!
    so yer go to pickies or any wreckers and bring a set of real small sockets, spanners and ring spanners aswell, all you have to do is unbolt each coil (6 bolts in total) and then the dfi module comes off aswell (try and get one with no corrosion)
    smack it on your commy and itll be sweet as.
  15. #15
    VS Commodore 3.8L
    Feb 2010
    Quote Originally Posted by Jxw View Post
    probably not that order if you want to save money, but having things replaced never hurts i guess
    plugs > leads > coil pack > dfi module
    dfi module and coil pack is like 30 bux
  16. #16
    1995 VS Calais
    Oct 2011
    Burn-City
    i had the same problem, even when cruising it would fluxuate between 1.5-2k rpm
    didnt have any codes for a while, there were some logged in my history for "tps" and eventually that code came back
    its essentially a part that tells the throttle what your doing and if it starts to die you will get a choppy acceleration. if it goes all together you could find yourself stuck in a gear.
  1. VN V6 S1 rough idle and jerky driving
    By lemusa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-02-2011, 02:49 PM
  2. Jerky VT
    By vt s in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-04-2009, 12:51 AM
  3. Acceleration Jerky
    By LowRyda2128 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-03-2009, 03:12 PM
  4. jerky take off
    By VSIIBerlinaL67 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-09-2006, 08:16 AM
  5. vp trip meter jerky & speedo "sticky"
    By daveyc in forum Electrical Wiring / Questions
    Last Post: 27-10-2004, 05:24 PM
