I have a 96 berlina v6 sedan, series 2, 240,000 k's on the clock, dual fuel, runs rather well, good condtion inside and out, one small knock on left rear door.
When it was brought, about 12 mths ago, had it servied, tuned on gas, they fixed heater hoses, as heater was not working, and replaced thermastat, ran well, of recent 6 mths, have notice it gets rather hot, the heat needle sits about half way up the dial 99 per cent of the time, goes to about 3/4 when sitting in traffic idle.
The radiator is full, and is running on coolant, the overflow is often empy and needs to be topped up very regularly, every 2 3 days, it has not boiled, however, when you stop driving, and if you take radiator cap off, it sometimes will spit up into the air, or just bubble
Any ideas????? Also when driving if climate control is off, hot air comes via the vents and center consol gets warm, feel it on left leg when driving????
Any ideas??????
Thanks
i just had the same problem with the temp rising in my vs when i was sitting in traffic but went back down when i was moving. it was the radiator fan not kicking in once the temp got to a certain level. could be that
Water pump and leaking radiator.
Water pumps get old, the blades on the pump wear away.
OK I was referring to this^.
Seems hot to me. My 8 gets to a little over 1/4 in traffic. Check your thermostat. If that's ok get it tested at a radiator place for exhaust gas and pressure test it if it passes all those your radiator is probably hmmm.. and you'll be right in front of a radiator shop!
Sounds like head gasket to me too.
