I thought i had a thread for this. but it would seem i dont. so im going to put all my pics up. i have a thread in SC but iv noticed there are people who hang here that dont hang at SC. so here goes.
started life like this
turned into this
and then i broke the timing chain after winning its class in my first entered drift comp. it never got re registered.
just a little fun. click image for video
its been through a few visual changes but this is one.
this is my T70. waiting with its friend the Corona 4 speed.
manifolds current state.
i have since decided to change the body work away from the stato look.
and todays effort.
Manifold it hideous i liked the first engine pic. i also like that front bar alot
Looks pretty sweet
I replaced the headlights in my car with strobe lights, so it looks like I'm the only one moving
its got kings superlows all round, monroe GTgas shocks, whiteline 30mm front sway, and 22mm rear. the fronts high coz theres no engine or gearbox in it atm.
the rear springs have been chopped, i spoke to kings about it, i had the superlow comfort springs in the rear and i wanted it firmer, they said i could cut out the thinner top coils, it would lower it and stiffen it up. so i chopped two coils out and now it sits just nice and is actually quite firm in the bum.
edit: and also Kmac camber bolts on the front and nolathane ball joint swaybar links.
How do you find it handles with them sway bar links i also like the first front bar you showed who built it
i built it. its half stato half R33 GTSt. iv just sold it too. to a fellow in VIC.
i found the handling good, but a little soft. when it was on the track, it had the front 30mm sway, stock rear sway, and superlows n gt gas shocks. iv since cut the soft part of the spring out n fatter rear sway bar, so im hoping the rear end doesnt float around quite so much, the way it was, it was very very tankslappy, but i used that to my advantage in a way as it was heavily underpowered due to the donk being built for a turbo but not having one yet. but im expecting it to be much more stable with better turn in as i havent driven it with the new setup including the balljointed swaybar links. still building the turbo bits for then engine, so its all out of the car.
What box are you going to run with your turbo set up, all vr/s are very floaty. My old vs was lowered and it floated bad, i done pretty much what you have said and it help alot, And with engine work it stop alot of floating, My irs vr how ever wasn't as bad. Atm its running upgraded links, A thicker sway bar, Ultra lows and a 4 camber kit, it know even now with a stock motor and half clapped auto sinks extremely well on corner's. Are the ball joint style links worth the money
i havent driven the ball joint links yet. and i got them free off nolathane as a trial thing. iv still gotta give them some feedback! lol the reason i changed, i was using the normal S links with the nolathane bushes, and kept splitting them. so i changed to rubber and kept splitting them. so i complained and they gave me a free set of ball joint style. so im hoping that my splitting bush problem is history.
iv got a toyota corona 4speed waiting to go in. thats one of the things stopping me putting the combo in the car, is the bellhousing, $610.00 worth! but iv finally saved up enough to order it tomorrow. so im hoping, that by the end of next week that it will be ready to go into the car! yay!
when i say floaty, as far as outright handling it was very solid. but when the rear came out, coz it was softer in the rear, it tended to pull the front over as well. you can sorta see in my avatar pic what im talking about. normal "grip" style driving was really stable but oversteer was floaty. shouldnt be now but![]()
yeah i know what you mean, personally i think you will have issues with the gear box should of bought a decent 5 speed supra box, My mate had the idea of a 4 speed to and spat it in a week of competeing
the five speed is the same as a four speed but with an overdrive. so he mustve got a dud. dellow rate the celica/corona box pretty highly. according to dellow the commodore T5 is only rated to about 250-300hp. in comparison the yota box is rated to 350-450hp. im aiming at about 400Hp with my combo.
well there ya go, looks to be a good set up pitty it wont see the street
its ok, im building a wagon as the tow car. its a VS but. at this point in time, its also getting a rebuild, but has a T25 planned for it. im tossing up between just dropping in an L67, or a 5L. but its on hold anyway... so theyre just empty ideas...
i just bought a wagon with a full vs clubby gear 6 speed manual, 195i motor, full exhaust system, lowered brand new suspension, full genuine interior, cluddy kit and 19s for 5 grand, black with a sunroof and all electrics except cruise control which i have getting fitted and modded for the clutch pedal also
new rims
[QUOTE=klampy;1848282]
NZ "Commodore Royale"
ha ha yea, i had seen that when i was researching. that wasnt my intention when i chose the bits though! lol. and iv since swapped that front end to my vs wagon so i have a Royale wagon!
iv taken my 19 inch chromes off the wags n lent them to my bro, seeing it with chasers on makes me wanna just slam it, matte black, and chome dress rims!
it will be moar low when the engine goes back in next week!!! getting soooo excited!
some daylight pics of the new fitment!
What have you done with the manifold and plenum?
manifold was originally cut open so i could gain access inside to smooth the plenum internals (its ported both up the runner and into the head, to the same size as the gasket). it then got a basic square top. iv since broken the engine (snapped cam chain) n it came out n got repaired, so figured when it goes back in its going to get the turbo it was built for. but didnt like the idea of a P/s throttle, so as we know turbos like big plenums. i hacked up an ecotec plenum to be able to use the TB and increase the volume, so it got welded up on top of the old box. so admittedly it probably doesnt need to be so tall but i did it for the internal volume with the aim of trying to eliminate uneven mixtures across the intake runners like the stock mani is plagued with.
it doesnt actually look like iv done much, but next to a stocker it looks massive.
its no where near finished of course. but im going to be closing off the opening where the elbow used to attatch, ill be cleaning up the the welds ( was my first n second attempt at TIG. EVER! lol ) and im going to inquire about an extrude hone. but not entirely sure if its worth doing.... depends on what its worth...
