Results 1 to 8 of 8
Thread: vs wheel offset?
    vs executive
    Feb 2011
    brisbane
    Default vs wheel offset?
    or what can it go up to down to would 50+ fit?
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    A bicycle
    Aug 2009
    Gippsland, Victoria
    offset depends on width too, remember.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Quote Originally Posted by NonStick Squid View Post
    @old mate you drive a vs ute therefore you're a bogan therefore your point is invalid
    vs executive
    Feb 2011
    brisbane
    oh okay cause i was lookinh at getting these
    20x9.5 Land Rover Discovery Range Rover Alloys Wheels | eBay
    theyre 5x120 which is right but 50P offset =[ does that mean theyd stick out from the body a ton?
    VR V6 turbo 4speed
    Sep 2007
    coffs harbour
    no, it means theyd suck under the guards by 2mm. standard commodore offset is 45-48p bigger number means tire in lower number means tire out.
    edit: but by 9.5, means if you run a 7inch rim as standard, you will have an extra inch either side. so in fact would sit closer to the guard.
    i didnt read ur post properly. rears should be fine, but not sure about fronts fitting under the strut.
    vs executive
    Feb 2011
    brisbane
    VR V6 turbo 4speed
    Sep 2007
    coffs harbour
    id be interested to see them fitted!
    edit: just out of curiosity, i had a look at the listing, and then played with an offset calculator,
    compared to a stock 48p 7 inch alloy, you will have 37mm less space to the strut, and it will sit 27mm closer to the guard.
    vs executive
    Feb 2011
    brisbane
    yeah well i got a list and its up there but first hopefully going to be lowering her this week or next
  1. wheel offset
    By themark in forum General
    Last Post: 03-01-2010, 06:51 PM
  2. Wheel Offset??
    By AntStu in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-06-2009, 09:16 PM
  3. VQ wheel offset...
    By sxchsv in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-08-2008, 12:48 PM
  4. VP wheel offset
    By mutley770 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-11-2006, 09:18 AM
  5. Wheel Offset?
    By 1991_Vn2nV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-06-2006, 10:31 AM
