Hey Guys, I have had a quite a few VR's and VS's but I never knew about the ADSL and the paper clip, I have always had to pay to get a scan tool put on it.
I have got a stupid question, it is telling me that I need to replace the TPS... I think I can work that but... This might sound like a Minda but... I need to replace the RH O2 Sensor, is it on the drivers side or the passengers side? Seeing it is a RH drive vehicle it is on the drivers side. Can anyone confirm this?
there are two oxygen sensors, these are located on the exhaust manifolds where the manifold collects from 3 into 1 on each side of the motor. if it says the RH sensor it is on the drivers side manifold, but if your going to do one sensor you might as well do the other while your at it.
so to answer your question in short, is on the drivers side.
Smith
Thanks Smithy.. That was what I thought... That is this weekends job, it is running as rich as..
