Results 1 to 3 of 3
Thread: Power Steering or Airbag?
    1997 VS Berlina
    Apr 2011
    South Sydney
    Default Power Steering or Airbag?
    I have a VS Berlina with driver side airbag and power steering and at low speeds there is a loud squeaking coming from somewhere along the steering column. Does anyone know what this could be? I've recently changed power steering fluid but ive always had this problem way before that. I've heard it could be the airbag. Is there any way to stop it because its really getting on my nerves.
    Chris
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It probably is coming from the steering column - where the column passes thru the firewall there is a grommet which gets dry and squeaks when the wheel is turned. The easiest way to stop this squeak is to lubricate this grommet - either from under the car (best method), or spraying WD40 over the general area under the brake master cylinder. You may also be able to spray WD40 using a spray tube from inside the car if you push the carpet out of the way. It's better to use a longer lasting oil than WD40 by the way.
    1997 VS Berlina
    Apr 2011
    South Sydney
    ok thanks heaps ill look into that
  1. [VR-VS] How to put an SRS Airbag steering wheel centre on your non airbag car
    By HamaTime™ in forum Holden Commodore How-To's
    Last Post: 18-06-2010, 10:48 PM
  2. [SA] *WTB* non airbag VR/VS steering wheel
    By 02DUBH in forum Swap / Wanted to Buy / Trade
    Last Post: 23-08-2009, 11:02 AM
  3. VS Airbag Steering Wheel
    By HamaTime™ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2009, 02:59 PM
  4. vy steering wheel and airbag on vt?
    By sp001in in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2009, 02:02 PM
  5. VS Airbag Steering Wheel??
    By Torquen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-09-2006, 10:30 PM
