Results 1 to 5 of 5
Thread: vs series 3 motor with a t-5
    1991 vg ute
    Apr 2011
    macarthur vic
    Default vs series 3 motor with a t-5
    hi, i am just wondeing if a t-5 gearbox can be bolted up to a series 3 vs motor?? thanks
    jesse_lankey is offline what to put here?
    VS S3 Ute
    Jan 2010
    yes, im assuming its a v6 your talking about, i'm pretty sure the looms are different you may have to get a series 1 manual loom?
    1991 vg ute
    Apr 2011
    macarthur vic
    ok thanks, is the bellhousings the same. And yea i am talkin bout a v6 sorry should have said that
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Yes you can but dont forget you'll also need the other T5 manual parts such as clutch, flywheel, loom, clutch cable and tailshaft etc. Do you mean the bellhousings between the T5 and Getrag box's? If so then no they are different as the Getrag bellhousing is part of the box casing and cannot be detached like the T5. Both though have the same pattern to the back of the block.
    1991 vg ute
    Apr 2011
    macarthur vic
    thanks mate
  1. Series 1 motor with series 2 radiator, can it work?
    By DAVIDC in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-05-2012, 11:56 PM
  2. series 2 vq with series 2 vn motor, almost stalls between park and reverse and drive
    By sp001in in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-05-2011, 11:49 AM
  3. Series 2 engine parts onto a series 1 vn motor
    By v6vpute in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-10-2010, 05:19 PM
  4. Wiring Issue VN - After Series 2 motor put in Series 1 car
    By ghog1726 in forum Electrical Wiring / Questions
    Last Post: 18-04-2009, 03:30 PM
  5. Will a VN series 1 manual g/box fit onto VP series 2 motor?
    By VPioneer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2007, 05:27 PM
