Results 1 to 16 of 16
Thread: what's the go with these pipe's?
    Did have VS Berlina now have VT Berlina
    Mar 2010
    Cockatoo Vic
    Default what's the go with these pipe's?
    Every time i have tried to take one of these out of a VS and up it all ways snaps off at the end that sticks into the water pump (you can't see it in this photo tho)
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    That goes into you're water pump!
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    VR V6 turbo 4speed
    Sep 2007
    coffs harbour
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Never had a problem. Done quite a few aswell. Must be your technique. Dont be so rough.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    vs caprice
    Dec 2010
    brisbane
    Mar 2010
    Cockatoo Vic
    Quote Originally Posted by vscaprice98 View Post
    if u snap one again i suggest that job is not for u
    lol
    Hahaha Yer we will find out 2morrow i will go down to the wreckers and pull a couple of them off and see what luck i have
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    I snaped one, wasent my engine. I said it felt to tight but he just said keep going
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    Mar 2010
    Cockatoo Vic
    Quote Originally Posted by mischa View Post
    yer well both times i did it i did the same thing as you body i told myself to do it LOL
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    Ive never broken one amazingly i have how every shared the input shaft to the water pump clean in half some how
    Mar 2010
    Cockatoo Vic
    Vr acclaim
    Jun 2010
    Cracka is offline Banned :P
    Old Sneakers
    Mar 2011
    Croydon
    heheh, ive broken one too, the trick is to gently lever it evenly out.
    Was a mongrel to get the broken bit out of the hole too.
    Mar 2010
    Cockatoo Vic
    Okay so i went to the wreckers and both of times i tried taking them out of to different cars they both came out easy where is i couldn't get it out of my car 2 time's with out braking it
    96 VS Wagon
    Mar 2011
    Nth Brisbane
    Keep the coolant with lubricant fresh in your engine and parts like this wont corrode and sieze
  15. #15
    Mar 2010
    Cockatoo Vic
    Quote Originally Posted by Paul13pp View Post
    Ever since i have had this car (April 2010) it has had coolant in it but the person i brought it from didn't look after the car to well that's why i'm pulling most of the thing's apart to fix or clean like right now im doing the manifold gasket and im going to clean all the top of the motor and part's maybe spray paint it all silver again to make it look a bit more new
  16. #16
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    If they are tight its just a matter of carefully leavering on each side. It will snap when the 'male' part sits slightly off line and catches on the tube.
    Ive snapped one before due to being a bit impatient lol
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
