Results 1 to 3 of 3
Thread: VR Power Steering PUMP removal instructions
    VT Series II SS Sedan
    Jul 2005
    Default VR Power Steering PUMP removal instructions
    I am searchiong for the instructions, step by step for a neighbour any help, links etc would be appreciated.
    The vehicle is a V6, VR Commodore.
    TIA
    Current Ride = 1999 VT II SS GenIII
    Previous Commodores - VT 9C1 Ex-Cop Car, VT Executive Sedan and Wagon, VS Executive Wagon, VP, VH, VC Sedans
    Other Holdens = Jackaroo, Lots of HQ's including GTS Replica, LC Torana, EH Ute
    S13 Silvia, VR S2 Exec, VX equpe, VE omega
    Mar 2011
    its pretty easy. Ill go off memory.
    1-remove the 4x 10mm bolts on the power steering pump pulley
    2-remove serpentine belt
    3-remove the small power steering line going to the resivior and catch all the fluid so it doesn't spill.
    4-remove the 3 8mm bolts holding the reservoir on to the pump.
    5-losen the metal hard line thats connected at the back of the pump. you will need to use an open end spanner but one of those crows foot (flare nut) spanners work best. I think its the closest imperial size to either 15mm or 17mm
    6- remove the 3 bolts (17 or 19mm) which hold the pump to the motor/tensioner bracket.
    install is the reverse of removal
    Jul 2005
    Thank you for your reply
    very much appreciated
  1. power steering removal & instillation
    By sally in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-03-2011, 08:13 AM
  2. Power Steering Pully Removal
    By Jimmish in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2011, 10:28 PM
  3. Power Steering Pump Removal/Installation VN/VP
    By jetspin_vn in forum Holden Commodore How-To's
    Last Post: 29-04-2010, 03:35 PM
  4. Steering Pump. Front shaft removal?
    By gontix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-05-2009, 01:25 PM
  5. Replies: 1
    Last Post: 09-11-2008, 09:18 AM
