Results 1 to 13 of 13
Thread: Vr front gearbox seal leaking after new front seal replaced
    1994 Vr berlina 3.8 v6
    Mar 2011
    Christchurch, NewZealand
    Default Vr front gearbox seal leaking after new front seal replaced
    Hey i had the vr auto gearbox out and replaced the front seal for the torque converter, I then put the box back into the car.
    Took the car for a drive, when i got home i looked under the car to be disapointed as its still leaking. Now im not sure if it will be the pump problem? Or the converter shaft not sealing due to any pitting on the shaft? I noticed some discolouration on the converter shaft, but no obvious pitting.
    Any ideas are welcome thanks.
    Pete
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    there looks to be a pump bush behind the seal did you replace that with the seal? if not it's prob it.
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    I totally forgot about that bush, You will need a new seal to replace this bush as they dont seal to good after pulling them out.
    Mar 2011
    What tool would i need to pull this bush out? And do i take the bush out the same way i put the seal in? In other words is it a gearbox shop job?
    Vr acclaim
    Jun 2010
    No you can do it at home, from memory they just push on, dont hold me to it though
    VS Berlina soon to be 5L
    Aug 2010
    Girrawheen
    seriously WTF the bush needs to be pressed in, suggest you take it to a tranny shop obviously dont know what your talking about.
    Mar 2011
    Sorry bout the super late reply guys. I took my auto into the shop, and it needed a new front pump housing, bus, the bearing had turned in its housing. A new rotor i think its called, and a new vaine or two. It going ok. I still think its playing up from 51kph through to 70ish Kph. Put my foot down at 50kph and it give me ok power. put my foot down at 51 kph and it builds up the power at the last minute... not that impressive at all.
    Any ideas?
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    Get a laptop or logging device like scantool to check sliprpm while driving, clutches are prob slipping, is oil good?
    Mar 2011
    Yea oil is all good, good reading on the stick. Doesn't leak any more at the moment. I know my cars done 285,000 plus, but now and then it will give me good power, and other times it sucks...
    Aug 2010
    Girrawheen
    so theyjust replaced the pump and didnt rebuild box. hmm sounds a bit suss hope you get it sorted
    Mar 2011
    Yes just the pump side of things i spose. thats all i really wanted to be done. What other things do they do when it comes to the auto gearbox?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    With those K's, the box probably needs a full overhaul.....about $2000....try a can of "Stop Slip" - any reputable brand.....this will reduce the slip and make the box last a bit longer....costs about $15.
    Mar 2011
    Ok, is that the only name its called.? I will try it, hopfully if that works, then i will know what to get fixed? the bands?
  1. rear main seal replaced.. still leaking
    By 96 Calais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2012, 01:38 PM
  2. Front Crankshaft Seal, Hard to do?
    By Deneo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-02-2010, 09:39 AM
  3. Front Oil Seal
    By Daveydee in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-11-2009, 01:40 PM
  4. front tranny seal
    By prjacksonau in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-09-2009, 05:40 PM
  5. Should I replace the front crank seal?
    By Wagon_Wheel in forum General
    Last Post: 21-12-2008, 01:16 PM
