Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By getadeal
Thread: fuel leak engine bay vr v8
    vs ute
    Mar 2007
    Question fuel leak engine bay vr v8
    when i started my car this morning i noticed a strong fuel smell, so i opened the bonnet and found fuel dripping from the back passengers side fuel rail.
    there is a line that runs into the fuel rail that may be leaking (hard to tell) or can any one tell me if there is an o ring in this location that is common to leaking and how hard to change cost etc.
    vs ute
    Mar 2007
    VR 215i Senator M6
    Apr 2011
    Sorry to dig this up, mine is leaking drivers side at the rear of the fuel rail. Very hard to see down there... would it be o-ring or cracked hose?
    VS Berlina V6
    Sep 2008
    It would be the o ring, there is a bolt on the back of the fuel rail undo this and pull out the fitting (there shouldn't be any pressure if it is all ready leaking) There is an o ring on the fitting replace it and refit and all should be good.
    VR 215i Senator M6
    Apr 2011
    Ok so took off my engine covers to find this =
    fuel leak engine bay vr v8-2011-08-29-15.47.55.jpgfuel leak engine bay vr v8-2011-08-29-15.48.23.jpg
    Its on the drivers side at the rear of the fuel rail, is that the fuel return hose? Its completely cracked and rooted....
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by HSV557 View Post
    Click image for larger version.
Name:	2011-08-29 15.47.55.jpg
ID:	123802Click image for larger version.
Name:	2011-08-29 15.48.23.jpg
    That would be the vacum line for the fuel regulator, if fuel is comming out of the the regulator vacum line connection then I am sure it means the regulator is in need of replaceing as well.
    VR 215i Senator M6
    Apr 2011
    replaced the regulator on the passenger side not too long ago. Ive done a quick fix with some tube and tape but if its a vaccuum its not going to do so well until i get another tube... maybe the fuel is leaking from somewhere else in the area. Thats good news about the vaccuum, explains the fuel surges ive been having. Thanks
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Well it looks like a regulator, yours a V8? did not think they had two regulators?
    VR 215i Senator M6
    Apr 2011
    This is where my problem is....
    There is another one at the front looks a bit rusted/stained
    And this is what i thought was the regulator? which i replaced.
    VR 215i Senator M6
    Apr 2011
    VR 215i Senator M6
    Apr 2011
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Pretty sure that thing is the fuel damper...or whatever they call it. Takes the pulsing out of the fuel line.
    Reaper
    Jun 2005
    hi there i had thje same fuel leak ,i tightened the fuel hose and that fixed it .
    Quote Originally Posted by vs hay hauler View Post
    aussie4life11's Avatar
    aussie4life11 is offline backyard argument starter
    94 vr 3.8l v6 Auto Series 2 Acclaim
    Oct 2011
    Geraldton, Western Australia
    umm dude, sorry to burst you bubble but this thread has been inactive since 09/11. and that would commonly be known as a thread dig. also, your information isnt very helpful. im sure the OP thought to tighten the bolts
  1. Vr fuel leak into engine
    By ozengines in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-11-2010, 07:59 PM
  2. vt fuel leak
    By jjbird85 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-09-2010, 04:57 PM
  3. Fuel leak??
    By 1994 CoMMy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2007, 08:19 PM
  4. Engine bay fuel leak
    By s_pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-10-2007, 09:41 PM
  5. HELP! VP Engine Fuel Leak.
    By azkwazere in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-09-2005, 01:14 AM
