Results 1 to 13 of 13
Thread: VS V6 Water pump replacement.... Again
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    Default VS V6 Water pump replacement.... Again
    Hi All,
    Looks like the water pump in the folk's VS is kaput again, the tell tale leaking of coolant behind the pulley down on to the crankshaft symptom is showing. I know what to do in terms of replacing the current one, but where is the best place to buy one these days? The current one wouldn't be much older than 3 or 4 years old, so I'm after something that isn't rubbish quality like the one currently in there. This will be the third replacement in just 160,000km, and the car has always had good quality coolant at the correct ratio.
    So just after recommendations on where to buy, and what sort of price I could expect to pay these days. I'm pretty sure that they all come with a gasket too, but is there any other sealant required in addition to the gasket supplied?
    Cheers!
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    i always use a good sealant i always buy mine from a local spare parts place, there the same as what you get from supercheap and never had a problem
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    mate these days they go for around $100 i got quoted that the other week from bursons. I got an elcheapo from superdodgey for $62 with 20% i was tight with money and needed to do it. I wouldnt buy another as the center hub is too small for the pulley so all the load is put on the 4 bolts that bolt pulley to water pump
    You need sealant for the bolts that go through to water i use holden genuine sealant comes in a tin for $50 last ages though. i also use loctite no.3 for gasket and surfaces (aviation sealant) you can use this on the bolts if you dont wish to buy holden sealant its best all round sealant i reckon
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    Mar 2008
    i normally use a GMB brand water pump from memory i think they are around the $70 mark
    there are a lot of cheap ones on ebay, but i dont know what they are like
    i always put sealant around it, i normally use a black hi temp sealant
    or the stuff they call blue goo, a blue sealant is fine
    Vr acclaim
    Jun 2010
    vs commodore
    Oct 2009
    Tamworth NSW
    I have just replaced my GMB brand pump on my VSV6 with another GMB brand pump that was in a "motorgear" box from bursons..My old pump was there for 6 years,it was still ok,it was just starting to weep coolant out the weep hole which is a sign the pumps seal is on its way out,but 6 years isnt too bad I reckon,I hope the new one lasts just as long.I paid $100 for it from bursons..Holden wanted $180 for a genuine pump,and they needed the engine number as there was a slightly different pump used half way through the VS series after a certain engine number...The GMB pump I got is universal fit,it comes with a shim that is fitted behind the water pump pulley if you have the later type of ecotec...
    Dec 2005
    Glen Waverley VIC
    Ended up replacing the pump today, ended up going with a genuine one from Holden, they did mention that they needed the engine number to confirm which pump was correct, so got that all sorted. Fairly straight forward job, except for removing the old paper gasket, that was a huge hassle. Took forever to get all the bits off. Also an idea to remove the power steering pump pulley, makes access to the lower left water pump bolt much easier. Bolted it all back up and filled with coolant, and no leaks so far. Bled the system up, and topped up with coolant, will have to double check tomorrow morning when everything has cooled down again.
    Cheers for all the info and suggestions.
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by Harvs82 View Post
    How much did you pay for the genuine pump?
    Dec 2005
    Glen Waverley VIC
    $150, was the last one they had that suited my engine. I was expecting it to be something like that anyway, as the non genuine ones I'd been quoted around $80 to $100 for anyway. The one I replaced was a GMB one, made in Japan, so I'm surprised that it failed after only a few years.
    VR wagon, 5 ltr ski boat,
    Sep 2009
    Broome
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    I bought one from supercheap today for 78 bucks. Was a Protex or something brand, can't remember exactly, the box is in the bin and the pump's on the car now. One thing I did notice was the impeller on the one I replaced(the bearing was farked)was a pressed type while the impeller on the new one was a cast type.
    I've always been under the impression that the cast type impeller is better, at least on the older engines.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    + 1 for the protex water pump from super cheap. I fitted one to the VX & VR, Both been strong for a good few years now :-)
    Sep 2009
    Broome
    Just had to replace the GMB pump again yesterday as the Belt tore out my bonnet lining and lower rad hose. The belt didnt drive off but jumped 3 ridges and flew apart. The pump bearing failed. It feels fine in the bearing and not leaking just the shaft wobbles...I also found the funny noise that was coming from the front of the engine that stoped a few weeks ago. The impeller was machining the timing chain cover. Fitted a Master Part, Made in the PRC .
  1. Water Pump Replacement
    By cucmbere in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-11-2010, 04:54 PM
  2. VR V6 water pump replacement
    By Skater_jj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-12-2009, 02:15 PM
  3. water pump replacement
    By steak000 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-01-2009, 11:55 PM
  4. Water pump replacement
    By Brumbies 5L in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-03-2007, 12:28 PM
  5. Vl Water Pump Replacement
    By PCJ in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-05-2004, 10:53 PM
