Results 1 to 7 of 7
Thread: car alarm and emoblizer
    VS Executive S2
    May 2011
    Dubbo NSW
    Red face car alarm and emoblizer
    can some one explain to me how to disconnect the car alarm and emoblizer... i dont know much about wiring lol... just brought a vs s2 looking to do up the guy i brought it off said the alarm kept screaming of its nut so he disconnected the battery which it does... i want to start the car to see if anything major is wrong with it, the car whines over but theres no spark from the sparkplugs im thinking that seeing the coil is all eletric that the emoblizer is shutting it all down???? thanx for who can help
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    if its an aftermarket immobiliser all you can do is trace the wiring IT HAS and cut it out then work from there....
    is why i dont like immobilisers.... killswitch anyday
    if its an alarm with a key hole on the side of it you can break it and turn it off using the key switch inside if you dont damage
    the insides of it when you get to the key switch
    VS Executive S2
    May 2011
    Dubbo NSW
    hammer and srewdriver it is then hahaha, i pulled the cover of the wires going into it and cut the black wire it stoped screaming but then im still faced with the same problem that why i thought if i would rip it all out and re-wire the wires to the the igintion ??? maybe i dont know... see i dont know what wires to join from the igintion either red, black pink, purple yellow hahaha????
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    no only if it has key hole on its case (alarm sirens case) can you break into the case and break the
    key barrel and turn it off like it wasnt there
    VS Executive S2
    May 2011
    Dubbo NSW
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    if it has a key on the side yes
    if you had the key (you wish about now) you just turn the key in the hole and thats it alarm is off
    it wont sound anymore in a cheap model but may still cut spark or fuel
    in the more expensive systems you turn key and it turns it all off back to normal
    as there keys are security grade and are too hard too pick
    at the end of the day you will likely have to remove the immobiliser system or pay an auto elecie to remove it and repair the harness
    where it was installed... best long term solution~!
    VS Executive S2
    May 2011
    Dubbo NSW
    thank you for the info champ.. thats great
  1. vx alarm
    By miltiadis_s in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-09-2009, 07:19 PM
  2. DIY alarm help
    By paulbenning in forum Electrical Wiring / Questions
    Last Post: 13-09-2009, 10:49 AM
  3. car alarm.
    By Humm in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-02-2009, 01:37 AM
  4. VX S - Best Car Alarm to get?
    By grimavxs in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-04-2008, 04:31 PM
  5. alarm
    By Sp0tteh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-01-2007, 10:47 PM
