Results 1 to 5 of 5
Thread: How in gods name do i remove this front panel!?
    VS dream is offline Lets go cruising!
    VS Executvie SeriesII
    Oct 2010
    Frankston, Victoria
    Default How in gods name do i remove this front panel!?
    the front passenger side panel on my vs seems to be un removeable, any secret pins or bolts? also rear bumper bolt locations please someone!
    Originally Posted by crewsy
    Non turbo, normal POS lancer.. although he has a G-reddy sticker on the back so it must go hell fast
    VS Executive S2
    May 2011
    Dubbo NSW
    two-bit's Avatar
    two-bit is offline Hiding between the posts
    vs S pac series II
    Sep 2010
    Altona
    rear bumper 4 along the boot then just pull each side its just clipped on, might be easier to break the bolts along the boot as they are plastic and get new ones they are a pain to get out
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    There are bolts along the quarter panel, 1 or 2 bolts under the quarter and then you will need to remove the black door jam (The black strip that runs along the top of the doors from front to back) Then there will be 1 bolt to undo
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    Also forgot, that there will be a nut on a threaded stud in the inside of inner guard holding on the front bumper.
  1. VE - Remove Sunroof Switch/Panel
    By itsn8o in forum VE Holden Commodore (2006 - ?)
    Last Post: 26-04-2011, 11:05 AM
  2. how do you remove the panel running along the doors?
    By chris_93 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-03-2011, 02:39 AM
  3. how to remove radio/heat/ac facia panel
    By glenn l in forum VE Holden Commodore (2006 - ?)
    Last Post: 30-09-2010, 05:05 PM
  4. How to remove vt fuse panel under steering wheel?
    By fabz in forum Electrical Wiring / Questions
    Last Post: 11-02-2009, 03:53 PM
  5. Gods Kitchen!
    By WNTDVT in forum The Pub
    Last Post: 11-08-2006, 06:55 PM
