Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By Brett_jjj
Thread: Is this true?
    VS Equipe
    Jan 2011
    Adelaide, SA
    Default Is this true?
    Hi Guys
    I have only owned a couple of EFI cars over the years (including my current VS)
    and my question to you is, I know with some modern injected cars if you have the battery disconnected for more than 2 hours it resets the ECU and you have to drive them gently when you reset it as it will adapt to your driving style for fuel economy
    Does this exist with the VS or is it just for newer cars?
    96' VS Equipe (Current Project/Weekender) (CLICK HERE)
    Resident VR/VS Addict
    VE S2 SV6/A6
    Apr 2011
    In my current non Holden, I have to disconnect the battery for 12+ hours or reset the ECU in other ways.
    Once reconnected, drive it like you stole it so when it's in learning mode, then it knows how it will be driven.
    This is similar to an Italian tune up on order cars, flog them to teach them a lesson
    Current Ride: 2011 VE Sedan - In Voodoo of course.
    Last Ride: 2004 Subaru Liberty GT, Twin scroll turbo, tuned, Bilsteins, sway bars, no rice, 420Nm
    Also Own: 1964 EH Wagon, modified interior, minor modifications outside
    vs commodore
    Oct 2009
    Tamworth NSW
    The ECU will reset in these cars after the battery is disconnected for a minute or two.The earlier V6's need their idle reset after their ECU is reset,this is done by reving the engine for a minute or two at 3000 rpm,the ecotec and later V6's dont need this done,and as for driving it easy after its been reset,Ive never bothered doing that, and have never had a problem..You can also reset the ECU by removing the engine fuse for 10 seconds.The engine fuse is located under the bonnet in the fuse box...
  1. is this true?
    By TheStateo in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-07-2006, 02:18 AM
  2. is this true
    By craigvl038 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-05-2006, 09:31 PM
  3. sad but true
    By bazcom in forum Jokes/Humour
    Last Post: 28-03-2006, 06:53 PM
  4. Is It True?
    By bangers in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-03-2006, 06:33 PM
  5. Sad But True
    By tr3nt in forum The Pub
    Last Post: 26-02-2006, 12:34 PM
