Fuel filter or the coils it sounds like its not sparking properly
alrite fellas, just went and tried it again, i pulled leads 3 and 6 off the coil and then put them on again, and the car started YAY for me.
BUT the car is no longer starting again, so im thinking i need new coils
Alrite so the car just started, i ran it for a while to warm it up, then turned it off and started it again. She isnt starting very smoothly and after reading through a few threads i came across this:
"Problem solved - it was the fuel pump
It wouldn't start spinning due to worn bearings when very cold.
All good now"
I'm thinking mine is the same problem as it was cold last night and really bloody cold today.
Opinions??
It could be a number of things either singular or a combination of.
- Coils
- Leads
- Spark Plugs
- Fuel Pump
- Fuel Filter
etc etc etc. I doubt it's a worn bearing, as it's cranking but not firing so it's either a fuel delivery issue or spark/ignition issue.
Check the above
Said it in the 3rd post,also agree with HamaTime
Leads and plugs were changed 3 weeks ago
Fuel filter was changed 2,500km ago
So left with coils and fuel pump
disconnect the fuel pump fuse.
remove all the spark plugs and earth them to something metal on the engine. ie intake manifold. while you crank the motor over. get someone to check to see if all the plugs are firing. its easy to see them spark at night, it should be small but bright blue.
i have the same issue with mine
last night i drove it around the block cuz i wanted to see if it over heats
and as i was driving back to my house she just died on me and lucky it rolled 3 houses away from my house so i parked it on the side
tried jump starting tried everything i could checked the fault codes and came up with nothing im lost trying to figure out wtf is going wrong
any ideas guys ?
MY VS COMMODORE http://i295.photobucket.com/albums/m..._3720573_o.jpg
car starts first go every time again now, and i havnt touched or changed anything WTF?
wtf your lucky
mines been sitting there for 2 days
checked again nothing
it turns over once and stops
