Results 1 to 20 of 20
Like Tree1Likes
  • 1 Post By Clint_G
Thread: Vr reverse light switch ??
    vr wagon
    May 2011
    victoria
    Default Vr reverse light switch ??
    Hi Just new here.
    We have bought a vr wagon column shift auto and the reverse lights are playing up. Where do I find the reverse light switch?
    Thanks Mick
    NO RIDE AT THE MOMENT
    May 2011
    New South Wales
    Just get some new bulbs,never heard of a reverse light switch b4 until you asked about it,theres no such thing.
    vs ute
    May 2011
    Quote Originally Posted by gem05 View Post
    How do you think the lights turn on ?
    May 2011
    New South Wales
    Where is the switch located then
    VS Senator
    Oct 2009
    The reverse light switch should be in the column part around the steering wheel. In the normal autos they are attached to the side of the gear selector under neath the plastic console.
    VS Senator
    Oct 2009
    Well you dont flick a switch to turn on reverse lights they come on when you put the bloody car into reverse for crying out loud, if you do where is the switch whiteute?
    Do you know much about cars mate.
    May 2011
    New South Wales
    Yeah I think that I do but not as much as you
    VS Senator
    Oct 2009
    Yes they do. All cars have a reverse switch. How else do the lights turn on. Magic.
    VS Senator
    Oct 2009
    The commodore auto ones are on the selecter insode the car as i.stated above where the manual.ones are on the side of the box.
    May 2011
    New South Wales
    Ok mate thanx for that info
    VS Senator
    Oct 2009
    vt s pack manual
    May 2009
    gawler, adelaide
    LOL at the conversation...
    okay so its actually right on top of the collum, if you take the plastics around the collum and ignition its right on top, my old man used to have a vg ute collum. and these things are very very common to fail, if you hold it slightly out of gear do they come on but not when in the gear properly ? mine used to do that.
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    Dont worry gem05 if you've never had to deal with this problem before then you wouldnt know it exsisted(the switch that is)
    May 2011
    New South Wales
    I knew that it exsisted I just wanted some one to lose it and make them angry and start an arguement because I just had my car stolen and Im not happy at all
  15. #15
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    Quote Originally Posted by M DUBB View Post
    Hi Just new here.
    Thanks Mick
    when u jiggle or move the colom shift a little do the revurse lights pop on after you put into R ?my old vs ute had the prob WHEN im revURSING my lights didnt always come on....when i wiggled the t bar thay poppped on.
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
  16. #16
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I think the switch is actually on the side of the transmission - where the lever meets the trans. That's how the workshop manual shows it. This is for a column change auto wagon which the OP has...not a ute.
  17. #17
    VE series2 E3 HSV Clubby & VS Calais 5.0L
    Mar 2010
    Around WA
    There are two.
    The neutral start safety switch & the one located inside the car.
    the one on the transmission is about $160 & the one inside the car is about $60.
    The reverse lights are hooked into both I believe.
    I had to buy one for the wife's VR 5lt & I bought the one for the box. wrong one wasn't it.
    Oh well s*^t happens!
    I hope that helps you out.
  18. #18
    Sep 2005
    how hard was it to do the 1 on the tranny.....thanks in advanve
    Quote Originally Posted by BottleFedVS View Post
    There are two.
  19. #19
    Mar 2010
    Around WA
    It looks easy enough.
    just undo the three bolts from memory & unplug the switch on the side of the tranny.
    you will have to have the car up on jack stands & i think the tranny needs to be in neutral.
    installation should be reversal of removal procedure with attention to plugging the module in last.
  20. #20
    VS ute II
    Nov 2009
    Default Where to buy Reverse light switch
    I've been unable to track down a replacement reversing light switch for a VS manual gearbox. Does anyone have any suggestions where I might be able to find one?
  1. [QLD] WTB VS SIII / VT getrag reverse light switch
    By goingtoblow in forum Swap / Wanted to Buy / Trade
    Last Post: 21-03-2011, 06:24 PM
  2. reverse light switch
    By Holden V8 SS Ute in forum Electrical Wiring / Questions
    Last Post: 12-10-2008, 11:23 PM
  3. T700 gearbox reverse light switch.
    By rexsportwrx in forum Swap / Wanted to Buy / Trade
    Last Post: 28-04-2007, 10:24 PM
  4. FS. Reverse light switch - getrag
    By blu 5L ute in forum Parts And Other Items For Sale
    Last Post: 28-04-2006, 08:53 AM
