Results 1 to 3 of 3
Thread: VR Starting Problem....
    VR 1994
    May 2011
    Central Coast NSW
    Default VR Starting Problem....
    Hi
    I have a VR (94) V6 3.8Ltr which i recently bought (cheap!). While it runs ok it has this starting problem i just can't figure out.
    The problem is..
    When starting it normally it just cranks over but won't fire over, however if you pump the accelerator pedal while it's cranking it will fire over roughly (splutters and coughs) and either a) the revs fall and it dies or b) it will struggle for 5 seconds or so like its going to conk out until it reaches 1000rpm idle then smooths out. After that point it goes fine enough except sometimes when you put it into park or reverse it go's to die (when parking on an uphill or downhill it seems?).
    I should add that while the engine is struggling to get to proper idle it chugs a bit of black smoke out the tailpipe.
    In trying to hopefully fix this problem i have tried a fair few things but nothing has changed?
    So far i have replaced
    Fuel Pump\Fuel Filter
    Spark Plugs
    Cleaned the Throttle Body with Carby Cleaner (including the IAC and TPS).
    and also run countless bottles of Injector Cleaner through it (which does nothing)
    I recently took it to a mechanic and he said i was losing fuel pressure and i had weak ignition spark and it would cost big $$ to fix. he replaced my Fuel pressure regulator as he said it was leaking.
    Then went on to say i should probably get rid of it as it's not worth the money required to be spent but it go's pretty well and i'm not quite ready to give up on it yet!
    Just wanted to get a 2nd opinion on what may be the actual cause of this problem as i was thinking the fuel line but now maybe not? New Coil Packs\Spark leads maybe?
    I probably should mention the car has just over 300,000km's on the clock but go's pretty smooth and still has life in it!!
    Anyway hope someone can shed some light on this one!
    vr ute
    May 2011
    adelaide
    step up sensor on the botom of the throtle body my car was acting simalar on start p and at the lights
    took mine out yesterday pulleld the stem out and used a slicone spray to lube the guide and put it back in 100% cosistancey on start up now and cofidane at the lights.........10 min job new sensor i belive is 70 odd dollars
    VR 1994
    May 2011
    Central Coast NSW
    Hi
    Yeah i gave The "throttle position sensor" and "Idle Air control" thing a clean out along with the whole throttle body but no difference? I ran a "error code" check and got 12 (system ok) and the one that says a prob with ur "camshaft position sensor" so i removed that and cleaned it off and still no go!
    Anyway i've decided to scrap the engine completely as my neighbour just recently smashed his VS (in the rear) and is giving me the engine (174,000Km's on odometer) + helping me put it in with his engine crane!
    Thanks for the help and sorry it took me so long to reply but u all know how it is working all the time to pay for your car(s)
  1. Starting problem
    By tigerpm7 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-08-2010, 05:03 PM
  2. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  3. VN starting problem
    By wes_v8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-12-2006, 10:21 AM
  4. problem with vl starting
    By genuine SV5000 in forum Electrical Wiring / Questions
    Last Post: 09-12-2006, 11:01 PM
  5. Problem Starting??
    By vksimmo in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-11-2005, 09:08 PM
