Results 1 to 4 of 4
Thread: problems with my vr
    vr
    Apr 2010
    Default problems with my vr
    hey guys im still having trouble with my vr.after driving a few ks when the car heats up it keeps stalling and then wont start up for a few hours.ive done a computer test and it came up as code 12,which means system pass.ive got a feeling its got something to do with the fuel but not to sure.any ideas?
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    vr
    Apr 2010
    ok will do but wouldnt the cas show up on the computer test i did.and were is the DFI module.
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by brian101 View Post
    One would think it would report a fault, but it is known that a faulty CAS would cause the car to stall when hot... The DFI is under the coil packs... check the connections on the DFI as they might have corrosion on the connectors.
  1. Signal Problems Aand LPG Problems
    By reyyan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 08:33 AM
  2. VZ SS random problems starting and also lock problems.
    By alista in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-12-2010, 11:23 PM
  3. Id like to know common problems with air con in vt so i can diagnose my problems
    By dope505069 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2010, 03:21 PM
  4. vq 5L bcm problems
    By thomas86 in forum Electrical Wiring / Questions
    Last Post: 12-01-2010, 09:20 PM
  5. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
