Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By aceventura
Thread: vs calais v6 heater not working
    Oct 2004
    Default vs calais v6 heater not working
    hey all it was a bit chilly this morning and i flicked the heater on and it didnt work the car was at half temp and i hit the climate control and cranked up the heat and it was blowing cold air what could be wrong??
    cheers
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    Quote Originally Posted by scottmcguinness172 View Post
    cheers
    If the pipes inside the car are boiling hot, then the heating system (coolant circulation wise) is working correctly. Sounds like one of the sensors may not be giving the climate module the correct reading, for example, the outdoor ambient sensor might be saying its 35 deg C outside, and the system takes that into account thinking that heating is not required. The other thing is that it could be the air mix door not working properly, therefore only allowing cool air in, and completely bypassing the hot air created from the heater circuit. If you run a diagnostic code check on the Climate system you should be able to work out where the problem lies.the system relies on information from the sunlight sensor, air con evaporator sensor, interior temp sensor and exterior temp sensor in order to create the temperature specified on the system. Say its 5 degrees outside, and you have the system set to 23 degrees, the system uses the info from the exterior sensor and interior sensor and sunlight sensor to deduce that its colder in the car than the temp specified on the display. Therefore it will use a large amount of air that will pass through the heater core and through the warm air section of the air mix door. Once the temperature of 23 degrees is reached, the air mix door will change the ratio of hot and cold air from full heat to a mix of mainly fresh outside air but still with a little bit of warm air to maintain your desired temperature.
    In regards to the AUTO mode, this allows the system to automatically turn the A/C on if the cabin becomes too hot, as well as automatically selecting which vents are required for your set temperature, ie when heating the air is directed at your feet, then as the cabin warms up you get warm air on your feet and cool on your face, and then when the cabin reaches the set temp it will only blow air from the face vents. In addition to this, the fan speed is also automatic, so when heating when cold the fan will come on at a high speed once the coolant has warmed up, and then gradually reduce speed as the cabin warms up.
    The best way to run the system is to switch it into AUTO mode, and then turn off the airconditioning, as its just a waste of petrol especially in winter. That way the system still keeps every other mode in automatic, except that it won't use the airconditioning at all. When I had my Berlina this is what I used to do, and then in Summer, say on days over 28 degrees I would just run the AUTO mode, which worked very well, and even with the airconditioning running, it didn't make that much difference to fuel usage, as the airconditioning only cuts in and out to maintain the set temperature, it doesn't run flat out.
    Sorry for the long post, but hopefully that gives you an insight on the system. Perhaps try running the AUTO mode, and turning off the A/C and see how you go. MANUAL will appear on the display, but the fan icon will have an A next to it.
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Perhaps the heater tap is not working. See if you can turn the little lever on the tap by hand.
    MY RIDE
    VS executive
    May 2011
    Shellharbour
    I had this exact problem a few days ago, we took the heater tap off and just joined the hoses together left the heater running every time I was in the car and now its as hot as ever again.
    Oct 2004
    its only got a fairly new heater tap on it i put a new on on it about 6-8months ago i have tryed putting it on auto manual a/c on and off i have tryed everything
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    If your heater pipes are hot and you aren't getting any heat then your mixer may be the issue.
    If your heater core pipes are not heating up, pull the vacuum hose of the heater tap when the engine is warm (and running). If the heater core pipes heat up you have a problem with the vacuum solenoid or possibly the cc module. If nothing happens you may have a blockage somewhere in the system.
    Maybe look at:
    vr berlina heaters
    Heater valve
  1. Vt Calais heater not working??
    By bbb in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2010, 04:20 PM
  2. Heater fan not working
    By RyanNZ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-07-2010, 11:27 PM
  3. Heater not working in my VS
    By Gunzero in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2010, 01:34 PM
  4. vn heater not working
    By onlinejames in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-06-2009, 12:57 PM
  5. heater not working in vp calais
    By tysons_2001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2007, 05:45 PM
