Results 1 to 7 of 7
Thread: Struts
    VS Commodore
    Mar 2011
    Glendenning
    Default Struts
    Just got new struts and I will put them on this weekend. Do I need spring compressor as I have new springs as well and do the struts need to be torque wrench toghtened?
    Thanks
    Daz
    __________________________________________________ __________________
    In the beginning, God created the earth and rested.
    Then God created Man and rested.
    Then God created Woman. Since then, neither God nor Man has rested.
    vs commodore
    Oct 2009
    Tamworth NSW
    Yes and yes....A workshop manual will list all the tensions for the various nuts and bolts etc..Its best to follow a manual anyway when doing these sorts of jobs as its easy to stuff it up,even if youve done it a heap of times..
    elmaso's Avatar
    elmaso is offline PARTY AND BULLSHIT!
    VR Calais
    Jul 2010
    for the front springs i say its best to have one, not really needed for the rear though.
    VS Commodore
    Mar 2011
    Glendenning
    Thanks... so to save me some cash seeing i have to buy the tools now and not the manual, does anyone know what the tension is on the struts?? for the upper and the lower?
    vs commodore
    Oct 2009
    Tamworth NSW
    Id buy the workshop manual and the tools,the manual is gonna save you heaps of money and headaches in the long run..
    VS Commodore
    Mar 2011
    Glendenning
    just an FYI to all... the torque setting for the struts are 70-80 nm....
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by p8ence View Post
    It depends on what bolts you are talking about,theres the steering knuckle to suspension bolts and nuts,theres the ball joint clamp bolt,theres the support plate nuts,and theres the suspension crossmember mounting nuts,and the suspension unit to support plate nuts....And they all tighten to different tensions...
  1. are these the same ? (hsv struts to SSV struts)
    By geo41e in forum VE Holden Commodore (2006 - ?)
    Last Post: 23-08-2010, 07:22 PM
  2. vt struts into vn
    By vnv8calais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-10-2009, 01:27 AM
  3. vs struts to vp
    By lukas pukas in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-04-2007, 10:23 PM
  4. anyone used air struts before?
    By vrmica in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-01-2006, 08:55 AM
  5. Gas struts
    By fatboy2869 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-01-2006, 12:41 PM
