any time i switch vent to windscreen all i hear is hissing and air blows on my feet. thought it might be the switch so replaced with second hand but in the process lost the diagram for the location of the hoses on the rear of the switch. which colour goes to which position on the switch? and what is the problem with the windscreen vent? is it easy to fix? any help pls even a diagram. thanx.
vacumme box down behind the headunit area is leaking or a hose has come off. Ill see what i can find for diagram have you run a test on it?
VS climate control MODE Question.
See the yellow circles that is the part I replaced and all is good.
"Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
My VS II Berlina Wagon
MY12 II SV6 Sportwagon
+1 Vac solenoid box, if you need any help getting it out let me know![]()
nathans VY Calais - 'Calais 2.0' | VT Equipe | VS Calais **SOLD!**
