Results 1 to 3 of 3
Thread: manual conversion using vn box
    VS Executive
    Jan 2011
    new zealand
    Default manual conversion using vn box
    hey guys, ive found a vn manual conversion over here in NZ for $500. It comes with t5 gearbox, clutch, pressure plate, pedal box, clutch cable, fork, thrust bearing, shortended driveshaft, and a spacer to line up manual box to auto crank. Just wondering if this set up would fit my vs and if not what else would i need? I was planning getting it all retuned and chipped from a good shop over here once its all done.
    Haydz's Avatar
    Haydz is offline 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    youll need a new 8 bolt flywheel that suits an ecotec ( hard to find) failing that i know you can get a neutral balance flywheel that bolts to your pre existing auto flex plate
    1990 VG 5spd manual Ute
    Dec 2009
    Always wanted to do this, good luck with it!
  1. 304 manual conversion. V6 or V8 manual box easier/cheaper.
    By Rusty-Tim in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2011, 05:24 PM
  2. manual conversion
    By irvo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-12-2010, 01:43 PM
  3. Please Help, Doing manual conversion and i used the auto flexplate bolt on manual fly
    By xtreme_sony in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-06-2009, 08:52 PM
  4. WTB: Manual conversion or wrecked vn-vr manual
    By na3point8 in forum Parts And Other Items For Sale
    Last Post: 13-03-2007, 10:22 PM
  5. Vp manual conversion and vn auto conversion
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:08 PM
