Results 1 to 7 of 7
Thread: Thermo fan question
    VE series2 E3 HSV Clubby & VS Calais 5.0L
    Mar 2010
    Around WA
    Default Thermo fan question
    I have a VS 5.0lt that used to be a S/C V6. I've still got the wiring there for a thermo fan set-up.
    my question is can or does the VR V8 auto computer still control the thermo fans or has this circuit been removed from the pcm?
    if I do hook-up the fans to the harness using the original plug it just blows the #10 ignition fuse.
    this is what I feel I'm doing!
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    I have thermos in my 5ltr. All commodores had the thermo wiring as standard, v6(obviously) and the v8s too. I however ran the wiring to the relay box and just had it activate a bigger relay for the AU thermos i used. They basically melt the factory wiring harness. But yes you will have to get the output turned on in the ecu first as its disabled in the v8's.
    Reaper
    Mar 2010
    Around WA
    Vs Statesman 5.0 - Vn 8plus
    Jan 2011
    yeah mate u can do it yourself bro if u wanted too ? u can use x2 30amp relays or x1 60amp relay and splice that into the fuse so it doesnt draw the power on initial startup, also if u use au thermos make sure they fit threw ur auto lines that run into ur radiator, i had that problem they went straight threw the fans so left them off until i changed to a seperate trans cooler
    Mar 2010
    Around WA
    I've had a seperate Trans cooler since i bought the car.
    the thermos i've got i picked up on feebay. I think they will fit a mondeo originally.
    Jan 2011
    you can only try and see if you have them alreadi mate, just remove your fanshroud and clutch fan 1stly, then slide the thermos into place and see if they will fit etc before u do any unecessary wiring etc. let me know how u go also post pix if u can
    VrWagz1's Avatar
    May 2008
    wollongong
    AU thermos not that good of a fit
    Theres some pic's in this thread to have a look at the AU thermos
    Reaper
  1. thermo fan question
    By Bitemylip in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-07-2009, 06:33 PM
  2. Thermo fans question
    By Goon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-02-2009, 08:58 AM
  3. Thermo Fan Question
    By Flat_White in forum General
    Last Post: 12-07-2008, 08:45 AM
  4. VX II Thermo fans Question Do both go at once??
    By Decksta in forum Electrical Wiring / Questions
    Last Post: 04-09-2005, 07:37 PM
  5. VX II Thermo fans Question Do both go at once??
    By Decksta in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-09-2005, 10:02 PM
