Results 1 to 8 of 8
Thread: battery drain
    vr
    May 2011
    new zealand
    Default battery drain
    my battery has 4A drain on it all interior light bulbs have been take out all fuses are out alternator and battery are in perfect condition all relays are pulled out. but drain is still there. is there any components in the car that are not fused. im thinking starter motor. car is 1994 vr commodore
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Aftermarket immobiliser or aftermarket head unit can cause drain.....if not these try disconnecting alternator as the diodes can fail and short to earth. It will not be starter motor.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    4A!! Thats like having one headlamp on.
    As above, the alternator. Try disconnecting it and retesting the drain.
    vr
    May 2011
    new zealand
    alternator is removed still have the drain its got me stuffed all fuses and relays pulled so cant be a lamp the only other thing with a live feed is the starter motor wondering if the solanoid is slightly routed
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If you suspect the starter solenoid check if it's warm....if stone mother-less cold then that ain't it. As per my previous post, have you checked if car has aftermarket immobiliser or head unit fitted? - sometimes people wire both straight from the battery unfused which makes it hard to track down.
    VR wagon, 5 ltr ski boat,
    Sep 2009
    Broome
    After market sound system? amp still on or electric antenna motor slowly burning.
    1990 VG 5spd manual Ute
    Dec 2009
    I had the same problem, turns out temp sensor was faulty and engine fan was staying on.
    hope it helps
    96 vs calais series 1
    Apr 2011
    maroochydore
    call an auto elctrician, 2 collective minds are better then 1. call a few even.
  1. battery drain
    By wdrury in forum Electrical Wiring / Questions
    Last Post: 31-07-2010, 10:25 AM
  2. battery drain
    By wdrury in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-07-2010, 09:37 PM
  3. Drain on Battery when car off???
    By mattman in forum Electrical Wiring / Questions
    Last Post: 03-01-2010, 08:35 PM
  4. help battery drain in 24 hrs
    By red_vb in forum Electrical Wiring / Questions
    Last Post: 16-02-2009, 06:14 PM
  5. battery drain
    By shamden22 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-04-2006, 07:37 PM
