Results 1 to 2 of 2
Thread: fault code 16 on vs v6
    VY2 S, VS exec and VG ute
    Mar 2011
    east gippsland
    Default fault code 16 on vs v6
    CEL just came on, car decided it wouldnt change gear(manually would) - assuming "limp home mode" enabled. CEL goes off changes fine. Seems to only come one when the car warms up........not my car so I dont know at what temperature
    So got code 16, incosistant voltage to temp sensor. So I`ll check for a constant supply for 5v and condition of wiring.
    Is this the sensor near the goose neck?
    Is there anything else I could be checking for while I`m at it?
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    Code 16 - Coolant temperature Sensor voltage unstable
    so could be loose terminals at the temp sensor? or loose terminals at ecu? or dead sensor? or broken wire from sensor to ecu?(last one unlikely)
  1. Fault Code 19
    By Apeman69 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-09-2007, 05:11 PM
  2. code fault 68
    By COO1VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-05-2007, 03:42 PM
  3. code fault 68
    Last Post: 28-03-2007, 10:01 PM
  4. Fault code 13
    By hispeedvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2007, 08:38 AM
  5. Fault Code Help
    By TigerVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2005, 09:08 AM
