i noticed today while parked in a shed, that my dash- instrument and parking lights come on when i hit the brake pedal, has any one had this problem and how do you fix it.1994 vr
check your brake light globes
thanks,will check to see if there correct type.
As above.
You may have a single filament globe fitted in a brake/park socket.
Allso check you trailer plug for twisted or damaged wires behind the plug...If fitted!
fixed,found right hand side back had a single filament for light-stop instead of a double all good now thanks for the tips.
