Results 1 to 4 of 4
Thread: wet engine vs v8
    vs commodore 5.0L HSV Enhanced
    May 2011
    Murwillumbah
    Post wet engine vs v8
    Hey all help me please! I wet the engine bay of my vs v8 very slightly with the hose while it was running but before i could get in and keep it running it stalled and now it just winds over and will not start.
    2003 VYII S 3.8L M5
    Jul 2010
    NSW
    How long ago was it mate? May just need to give it some time to dry out and it should be fine, however not sure what problems arise while wetting an engine while its running, as it's fine to degrease an engine but yea your meant to cover up all the electric components... You could have just got some water in the ignition system?
    vn hsv wagon
    Apr 2011
    Frankston
    Mate you have water in the coil lead or if it was hot and you hosed it you can shock coil and thats the end of it.Check for spark at plug.Coil is down back of engine or you have water in the ignition moduel
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    So you needed to make two threads to ask the same thing?
  1. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  2. VS Ute Engine just fitted but engine light coming on and not going into overdrive
    By MX_Leigh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-10-2010, 04:53 PM
  3. vs 304 (5.0L) engine wiring diagram - engine dyno runs
    By chez00 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2009, 03:00 PM
  4. help needed identifying an engine based on the engine number
    By V6_Lux in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2008, 01:25 PM
  5. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
