Results 1 to 4 of 4
Thread: Error code 14 vr v8
    vs ute
    Mar 2007
    Default Error code 14 vr v8
    i have had a problem lately where the engine light comes on then go off for a while, with information obtained from this site, i have managed to retrieve an error code of 14.
    this code is ECT sensor voltage low auto trans code.IS this the engine coolant temp sensor or a sensor on the auto trans (as said by previous owner)
    vs commodore
    Oct 2009
    Tamworth NSW
    Error code 14 is an ECT (Engine Coolant Temperature) sensor fault,it has nothing to do with the auto trans.Just check the ECT wiring and connector and if it all looks ok,clear the error codes by removing the negative battery terminal for a minute or two,recheck the codes to make sure it cleared properly,then drive the car for half an hour or so, and then recheck the error codes again to see if the error code came back,if it did come back,then renew the ECT sensor.Try to only use genuine holden sensors when replacing them..
    vs ute
    Mar 2007
    Tried that today, looks like i am up for a new (Engine Coolant Temperature) sensor thanks for the info. Any idea how much they are from holden?
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Bought one in March from Holden - $11.
  1. error code 12, 3 times then code 76
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2010, 06:36 PM
  2. vx berlina traction and engine light come on intermittently/// error code error wtf
    By glennis in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-05-2010, 07:55 PM
  3. Error Code 22
    By jasonb in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-02-2009, 07:15 AM
  4. error code 27
    By ace_bowler2000 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-03-2008, 09:43 PM
  5. Code 14 what the hell is error code 14!@*&%#
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2005, 12:35 PM
