Results 1 to 12 of 12
Thread: can u fit irs to any vs?
    95 vr ss
    Nov 2010
    brisbane
    Default can u fit irs to any vs?
    had a slight 'mishap' in my vs ss race car
    will the irs fit in any vs shell? or do i need one that had irs?
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    95 vr ss
    Nov 2010
    brisbane
    Aug 2008
    NSW South Coast
    How much of the 'running gear' do you wish to transfer to a vt body? Motor to diff? Diff should transfer fine so long as its an irs model (vt series 1 was still rigid diff in some lower models) but may be a different track width? 5 litre will drop into a vt fine with the right k frame. I believe tailshaft will be different.
    95 vr ss
    Nov 2010
    brisbane
    ok
    but after thinkin i really need to stick with a vs shell so i can use all the other bits like cage etc but its much easier and cheaper to get a lower spec (non irs) shell
    is the floor pan of an irs and solid vs 'basically' the same, with the exception of the mounting points? the rear half of the car is ok...... so the thinking is can i cut the floor pan/mounts from the irs car and fit them into a non irs shell?
    ve sv6
    Aug 2010
    Quote Originally Posted by cander24 View Post
    not having a crack, but all vt's were irs.
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Quote Originally Posted by glenn l View Post
    I was about to say, you won't get the VS motor in the VT legally due to ADR/EPA but then I realised it was a race car.
    As long as it's IRS it's transferrable, with the correct VT mounts and K frame etc..
    I was also under the impression that every VT model IRS was standard equipment?
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    VS Executive s2
    Feb 2011
    Albury
    hamatime, i thought the vs and vt models had the same
    engine, or is it only the v6 ecotec that was the same??
    and the v8 completely different?
    Quote Originally Posted by Mumboman View Post
    I was lucky I got a lesbian.... She came out straight after it and I got my P's.... Happy endings for all
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    Some VT's used the 5ltr (series 1's)
    VT (series 2) was the beginning of the LS1
    Ecotec V6 was VS - VY
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    I would stick with the VS shell.
    You already have all the gear and its lighter than a VT.
    95 vr ss
    Nov 2010
    brisbane
    ok
    so everyone agrees that a non irs vs doesnt have the mounting points for an irs?
    also am i right in assuming all calais, ss and acclaims came with irs?
