Results 1 to 10 of 10
Thread: Transmission Problems
    VR
    May 2011
    New Zealand
    Default Transmission Problems
    I'm starting to wonder if I need a trans service or a new trans
    When I take off in the morning or even during the day, the trans seems to take a while to change gear, if I time it rightly I'll take my foot off the accelerator, it'll change gear.
    There's enough trans fluid in it.
    Anyone know of this problem, ideas of what I can do?
    Vs Statesman 5.0 - Vn 8plus
    Jan 2011
    sounds like its due for a service mate not a rebuild, just give it a good flush of new oil and slap a new filter in there and a good clean wen u pull it apart will be alright again mate
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    A new trans will cost upwards of $2000, so first try a service as suggested...will cost about $200. I'd also try an error code test which is very easy to do and may show up ant transmission problems: Checking error codes VR/VS (Revised)
    VR
    May 2011
    New Zealand
    Quote Originally Posted by hako View Post
    I ran a error code, it only flashed twice, is that a bad thing?
    VR
    May 2011
    New Zealand
    There's also a vibrating noise coming from somewhere, only when I slow right down, and sometimes when it's at idle, it does go away.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Quote Originally Posted by Lusitano View Post
    Which gear changes are you referring to? 1 -> 2, 2 -> 3, 3 -> 4, or all changes? Are the shifts harsh or normal?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Try the error code test again...read instructions carefully....if all is OK it will flash once and then two times meaning code 12... what you say may be 12??...if so then it means no fault codes logged.
    Re the 'vibrating noise' - as it happens at idle as well as when driving it will not be transmission related. What I would do is replace the plugs and leads....together they will cost about $80AUD to fit yourself. At the same time I'd add a tin of injector cleaner (go for the dearer ones...Nulon etc). This will get your ignition and injection system back to 'normal' unless you have other problems.
    I'd also spend a few hours going back over old posts on this forum looking for similar threads....it will also give you a bit better understanding of what is what (not mean't in a patronising manner!!!).
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    I also have the same problem and have posted a thread aswell,error codes show eveything is ok but I just want you to know hako I have gone back on all the threads as you have suggested and there isnt much there to find,do you suggest looking at other models threads not just the VR-VS?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    OP and EDGE3...check this link and see if anything sounds similar: 4l60e Problems and Solutions - S-10 Forum
    Feb 2011
    NEWCASTLE
    Thanx hako I will check the TPS to see if this is the problem as this sounds like what it might be
  1. transmission problems
    By knight_vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-06-2011, 12:20 PM
  2. VR Transmission Problems - Please Help!
    By suburbanmeth in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-06-2011, 12:34 PM
  3. Transmission problems
    By blackraven@ihug.co.nz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-10-2009, 06:53 PM
  4. Transmission problems
    By acarmody in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-09-2008, 09:32 AM
  5. Transmission problems??
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-02-2006, 11:19 PM
