Results 1 to 12 of 12
Thread: VR V8 Calais Fuel Inst not working??
    VR V8 Calais
    Jan 2010
    Hamilton NZ
    Default VR V8 Calais Fuel Inst not working??
    Hi there, I have recently purchased a VR V8 calais and the fuel inst, fuel usage and dist to empty functions in the trip computer don't seem to be working. With any amount of fuel in the tank the dist to empty reads about 1100kms but that's wishful thinking! Also the fuel usage reads 0.18 ish l/100kms which is also not very v8 like and is definitely using more fuel than that.
    Just wondering what controls this, I'm guessing it is a sensor somewhere maybe on the fuel rail to tell you how much fuel you are using?? No idea really, just a guess.
    I have a friend with a vn v8 calais and his trip functions work fine so if anyone knows where the sensor is please let me know and I can swap parts from his car to mine until it works again and then I can visit the wreckers for the faulty part knowing it's going to solve the problem. Just need to know where to start!!
    Cheers in advance.
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    Has the car been converted to gas? Because with my VS, if it's been running on gas for 100kms and not petrol then the fuel usage goes down and dist until empty goes up. Because the computer doesn't realise the car is running on lpg.
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    VR V8 Calais
    Jan 2010
    Hamilton NZ
    Yea I have checked the calibration, everything is set correctly. No it doesn't run on LPG and never has. Any other ideas anyone?
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Run the cluster in Diag mode see if it says "error" in the main screen. Should scrol though 3 screens - the last lights up all segments..
    and 3 Dangerous non ABS VN's
    VR V8 Calais
    Jan 2010
    Hamilton NZ
    Yea I have done that as well, everything works fine, all lights light up, just the fuel consumption numbers hardly change. Fuel used ranges from 0.18 - 0.23 ish and fuel inst is at 0 always and dist to empty will range from about 680 - 1100kms or so no matter how much gas is in the tank. Don't think it is a problem with the trip computer itself but I could be wrong. Cheers.
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by dropthaclutch View Post
    It most probably will be 1 of 3 things. 1) the continuity between the ECU and cluster including the cluster PCB and connectors (yellow black wire). 2) fulty trip compter in the cluster. 3) faulty ECO or memcal/tune.
    Fitting a test cluster is one thing to try. You could also try a replacement ECU/memcal.
    VR V8 Calais
    Jan 2010
    Hamilton NZ
    Ok cheers, will have to look into it. So is it the trip computer that controls the readouts? how/where does it get a signal to say how much fuel is being used etc? Or is it all to do with calibration in the computer that changes fuel used readouts with how many revs the engine is doing and the levels read from the 02 sensor in the exhaust? Really curious to find out how this system works, Cheers.
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    there's base rate calcs in the memcal then injector timing would help calculate your fuel readings.
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    The trip computer gets the information directly from the ECU. You manipulate what the trip computer reads out by changing the calibration numbers - It has no influence on what is going on under the hood.
    VP Exec
    Jun 2005
    Yep, ^ and ^^. The trip computer integrates (in the mathematical sense i.e. sums) the time that the injectors are opened for. With values for the fuel flow rate of the injectors: opening time X flow rate equals fuel consumed. With the input from the speed sensor then the fuel consumption rate per distance travelled can be calculated.
    VR V8 Calais
    Jan 2010
    Hamilton NZ
    That all makes sense cheers for that!
  1. VN Calais - Fuel Consumption on Trip Computer stopped working
    By Senna.In.The.Wet in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2010, 09:47 PM
  2. vn Calais rear lights, rear indicator, reverse lights and fuel gauge stop working
    By rustyguy085 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-11-2009, 08:25 PM
  3. Normal or Not, Vs Berlina INST Fuel Display
    By ORIXVywags in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-10-2009, 11:01 AM
  4. Need help inst LvL 3 Cluster
    By -=ApheX=- in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-06-2009, 01:05 PM
  5. fuel surge turning right? weird inst fuel readings
    By vkotis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2006, 12:00 PM
