Results 1 to 18 of 18
Like Tree1Likes
  • 1 Post By RX25SE
Thread: Tyre Noise :(
    VS Calais
    Oct 2009
    Baulkham Hills, NSW
    Default Tyre Noise :(
    Hey guys,
    I own a VS and have recently put 18's on the front with 235/40 profile, Sumo Firenza Tyres and am hearing a loud constant low whirring noise after about 50km/h from the front when I drive.
    The tyres arent scrubbing up against anything and I've played with all different types of tire pressures (lower psi lowers noise I've noticed)
    Besides possibly replace tyres, is there anything else that can be done to correct the problem? Or do I just put up with the noise?
    I'm fairly sure the tyres are the cause of the problem as when I put my 16's on everything is fine and quiet again :S
    Anyways, any suggestions? Ideas?
    Cheers guys
    VR Berlina
    Mar 2010
    sa
    Vs Statesman 5.0 - Vn 8plus
    Jan 2011
    nar man ur problem is the brand of tyre, theyre shit chinese crap mate...crap in the wet and give loud road noise...change to a better tyre maybe a korean or japanese tyre and u will eliminate these tyres..if u bought them new and theyre only a few hundred k's old u will be able to warranty them on noise -
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    Time for some new tyres man. That brand and the pattern is shitty. Its a cheap generic tyre.
    Basically you get what you pay for, find yourself a nice mid-range tyre.
    VR Berlina
    Mar 2010
    sa
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    VY SS
    May 2011
    Auckland
    Be careful lowering the pressure. Cheap tyres generally dont have great sidewalls and can bulge if you run at low pressure.
    I have pretty much no roadnoise on my potenzas. The neutons it had when i got it actually weren't too bad for a cheap tyre either. Don't buy dunlops every set my family has ever had scolloped!
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    As above, cheap and nasty.
    If Google images is correct, they have a directional tread pattern which are prone to noise. The compound is probably quite hard also, which wont help.
    If you want dead quiet, look for an asymetric or a non directional pattern.
    I have directional R spec tyres on my Subaru and they hum a bit too.
    Why do people spend $$$ on rims, then put cheap tyres on them? I don't get it.
    VS Calais
    Oct 2009
    Baulkham Hills, NSW
    Yeah, I Googled the Firenzas and saw alot of compaints about how noisy they are. I just didn't think they would be THAT loud. But I just realised a few hours after posting that they do look a bit camber worn too, so I don't think that'd help out with the quietness at all.
    And don't worry guys - I didn't buy the tyres new! I bought a set of rims that already had the tyres on them :P
    So then... any recommendations for a good mid-range tyre? Don't really need a top of the line tyre but don't want cheap shitty ones either...
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    These stick well, wet and dry.
    Hankook RS2.
    Classed as a road/track tyre but they are more a hi po street tyre.
    Treadwear is a little soft at 200, so don't expect them to be long wearing.
    Price seemed reasonable to me.
    vr94ss's Avatar
    vr94ss is offline walks barefoot
    VR SS '94
    Feb 2009
    Lismore, NSW
    It really depends on what you need the tyre to do, there's usually a compromise of some kind. It seems to be always raining here so I went a wet tyre. Pretty good on noise on the freeway up to Brissy and fantastic in the wet and great when it's dry. Uniroyal rainsport.
    VY SS
    May 2011
    Auckland
    Definitely shop around. When I got my 235-40-18 potenzas prices varied from 350 to 240nzd
    vz wagon
    Aug 2006
    Wild west of Melb
    Quote Originally Posted by RX25SE View Post
    Hankook RS2.
    that tyre will be noisy aswell as the noise comes down to the size of the block on the out side of the tyre the smaller the block the less noise it makes thats why most tyres have little groves on the very edge of the tread.
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Not as bad as you might think.
  15. #15
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    I have Firenzas in 17s on my car. A little bit of a humm to them, but grip perfectly fine to me... wet and dry and i drive the hills a lot!
    mate had them in 18s on his vy, the noise was so loud and he ended up replacing them after only a couple thousand kms
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
  16. #16
    VY SS Ute
    Jan 2011
    Hankook RS2 are an awesome tyre. I got 15,000km out of a set on my old Subaru, with a couple of track days and auto cross sessions as well. They aren't loud. Very stable under brakes.
    The RS3 will be out soon in Aus, which are supposed to be a significant upgrade.
    Also;
    Tire Rack - Your performance experts for tires and wheels
    Shipping for a set of four to Perth cost me $250. Worked out less than the cost of buying three of the same tyres locally.
  17. #17
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    Hankook tyres are a good tyre, but on my VS I tried Kumho KU31 and there is no road noise, only problem is in the wet the back wheels like to spin alot whether you accelerate hard or soft.
    I had Silverstone tyres on the VS before and they were ok when they were new but as the wore down they got very noisy and they didn't grip very well with still around 50-60% tread.
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
  18. #18
    VS Executive S1 Commodore
    Nov 2010
    hankook is a great tyre i had them for about 3 yrs, till i got 17's n the boss at work gave me continetal contisport tyres for free n they are brilliant, quite hold a little to well in the wet n dry but at 400 a tyre im glad i got 4 for free.
  1. Tyre noise?
    By bzzbqw in forum VE Holden Commodore (2006 - ?)
    Last Post: 08-03-2010, 02:36 PM
  2. VY S pac Tyre noise
    By red\/Y in forum VY Holden Commodore (2002 - 2004)
    Last Post: 17-04-2009, 06:14 AM
  3. tyre noise
    By BUSTER1 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-04-2007, 05:11 PM
  4. Tyre Noise --- Plz help
    By sno in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2006, 09:10 PM
  5. Noise From the Brake/Tyre
    By Jules86 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-07-2006, 09:48 PM
