Results 1 to 7 of 7
Thread: Live axle spring replacement.help
    1997 vs executive
    May 2011
    goulburn, work in canberra.
    Default Live axle spring replacement.help
    Hey looking for instructions on how to replace the rear springs on a live axle vs as i have super lows to put in and not 100% sure. i will be doing it at work so will have a hoist and every other tool under the sun..
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Very easy, raise car, unbolt top or bottom shock mount (your choice) this will allow you to remove old spring. install is reverse of the removal. may be easier with the wheels removed.
    Power is measured in DECIBEL
    1997 vs executive
    May 2011
    Vs Statesman 5.0 - Vn 8plus
    Jan 2011
    When you undo your shockers mate just rest something under them to take the load off the bolt so u don't strip it on the way out
    VS Commodore 3.8L
    Feb 2010
    i didnt even have to undo any bolts
    pretty much...
    jack car up
    take off wheel
    pull springs out, i just used my hands, but they were lows anyway
    put new springs in
    put wheel on
    unjack
    might have to use spring compressors if there just stock springs but. 20 bux at supercheap.
    shit easy
    vs commodore
    Oct 2009
    Tamworth NSW
    To remove the rear springs on a live axle model,I just jack up the rear of the car and sit it on chassis stands.Then I support the lower rear control arm with a jack and then remove the bottom rear control arm bolt, then I just lower the control arm down a bit with a jack.Its the quickest and easiest method Ive found to do this job,especially when the original height springs are fitted.It takes 30 seconds to undo this bolt,and another 20 seconds to lower the arm with the jack,too easy..
    spud_22's Avatar
    spud_22 is offline Ruled by the P
    95 VS Berlina
    Nov 2010
    Thanks guys just used your words of knowledge to put in some rear springs. cheers
  1. Wll VS live axle sedan, fit in live axle ute??
    By rooooboy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-10-2009, 08:08 PM
  2. quick help please vs live axle , axle swap
    By bwian in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2009, 02:20 PM
  3. Will VN Live Axle shocks and springs fit a live axle VR?
    By Andrew426 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-09-2009, 06:33 PM
  4. [QLD] Front and Rear King Spring Lows live axle
    By holden-4-life in forum Parts And Other Items For Sale
    Last Post: 02-05-2009, 06:27 PM
  5. live axle or IRS?
    By jayderichards in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-04-2008, 02:59 PM
