Results 1 to 8 of 8
Thread: VR Calais Fuel Problem
    St3alth187's Avatar
    St3alth187 is offline More time than money
    VR Calais 3.8L Manual
    May 2011
    Nyngan, NSW, Australia
    Default VR Calais Fuel Problem
    G'day guys, been searching the forums for a few days but cant find anything specific to my problem. I'll walk you through what has happened.
    Got the car with a 1/4 of a tank in it. Not a single problem with it at all. Apart from the bit where it goes back to idle on sharp right hand turns.
    I pulled up to the servo for the first time the other night to put about 10 litres in her. Went to leave. She winds over and over but doesnt fire. Did this for 5-6 times before the engine burst to life. Everything was fine from then on.
    Until the next day i put about 30 litres in the tank. And the same problem. Except this time i couldnt get it to start. Sitting there waiting for my friend to pick me up i fiddled with the fuel lines coming out of the tank ... at that time my friend pulled up and turned the key and it started. He said it might have something to do with the ignition. But i feel its related more to the fuel.
    I can hear the fuel pump priming. The problem seems to be when putting fuel in. So there must be something internally wrong..?
    Since then it seems to be a bit more reluctant to start.
    Any ideas?
    Jake =)
    Did have VS Berlina now have VT Berlina
    Mar 2010
    Cockatoo Vic
    the battery in your key might be going flat or the little pointy thing on the key might not be touching the ignition enough to let it spark but let it turn over
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Revs falling or engine stalling while sharp cornering is 99.99% always the fuel pump, or swirl pot around the fuel pump pickup. Even if you hear it priming doesn't mean its providing good pressure..
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    St3alth187's Avatar
    May 2011
    Sorry to dig up an old thread, but for future troubleshooting purposes:
    Vee-ard was correct, after replacing my fuel pump with no difference I eventually bought a whole new fuel tank + sender unit from a wreckers.
    Scott's Parts Plus - Dubbo were a pleasure to deal with and supplied a quality product, well packaged and presented. Highly recommended dealing with them if given the opportunity.
    It no longer dies around corners and im hoping this solves my starting issue !
    Cheers,
    Jake.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Glad u posted an update, always good to have an answer
    Hope its sorted, if not, I would be looking at the breather hoses on the tank or the charcoal canister. Sounds like its something to do with vapor
    vt 5litre aussie hydrolic roller worked
    Feb 2012
    narellan
    Quote Originally Posted by darcycammo View Post
    haha, an u where born fully qualified aye, be hard in person, that means face to face, thats all im goner give ya champ, otherwise id be as hard as u,,,, 1 bad ass computer hero
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by bradzhsv View Post
    I don't know how you got that from what he said. To me it seemed that he was trying to give advice, although it was not the problem in this case it can be the problem in some cases where a car won't start.
    MY RIDE
    St3alth187's Avatar
    May 2011
    Now that you mention it one of the lines running from the TB to the Charcoal canister is severed, and always has been since i've owned it. Do you think that would be a problem ?
    I didnt think the charcoal canister wasn't that important, shows what i know xD
    Cheers,
    Jake.
  1. VB Fuel Pump problem. no fuel getting to engine.
    By Vb paddockbasher in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-12-2010, 09:11 PM
  2. vs v8 fuel problem?
    By mUzZa88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-06-2010, 02:06 PM
  3. Fuel / Fuel gauge problem
    By 2ndLook in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-10-2009, 06:50 PM
  4. vp calais fuel guage problem
    By vl_davo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2008, 02:10 PM
  5. Average fuel level problem on Vs calais
    By L31GH in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-10-2007, 05:59 PM
