Results 1 to 11 of 11
Thread: Extractors on or off?
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Default Extractors on or off?
    Hi guys, Im just helping a mate put his engine back in (304) and we're wondering if its easier
    to re-install the engine with the extractors on already or should we take them off, drop
    the engine in then bolt them up after? He said he had issues with the flange getting in
    the way when pulling the engine out so im assuming its going to be a pain to get it back in with the extractors attatched?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I think it is easier to put the engine in with the extractors attached. Unless the rack is out, if the rack is out then it is just as easy it to do it either way.
    Or, you could put the extractors in position in the bay first, then lower the engine in and bolt them up.
    Visit my Facebook page
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    ok so we battled for an hour trying to get the engine in with the extractors on but it kept getting cought on the rack, so we unbolted the extractor and now its sitting on the mounts without any bolts in as it was getting dark. We will finish it off tomorrow.
    I have never fitted extractors as I have always had them installed when I upgrade the exhaust or they come already fitted, so my next question is, do I lift one side of the engine to fit them up or drop the rack?
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    If they are sitting in the engine bay already, just lower the engine down onto the mounts then bolt the extractors up to the heads. What car are they going in?
    VR 5.0 ltr Ute
    Nov 2009
    Beenleigh, QLD
    When I replaced mine I lowered the extractors down with the motor, not bolted up because i couldn't Get the motor in with them bolted on and I couldn't get them on after the motor was in.... So just go slow and get a mate to lower the motor as you slide the extractors down with it.
    "I realize you were young and inexperienced at the time, but in hindsight you should have chosen your parents more wisely."
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    Its in a VR Sedan, The extractor is in the garage now..lol. So looks like im going to have to pull the engine back out to slip the extractor into place... DOH!
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The RH one won't go in if the engine is in without undoing the and moving the rack over. You should be able to lift the engine a bit and slide the extractor into place.
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    you can jsut drop the rack ie remove 2 bolts from k frame and undo steering knuckle. but if the engines not bolted in i lift up slide the extractor in drop the engine back down then bolt it up can be a pain sometimes getting the knuckle back on the rack
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    As pub said, lift the engine a touch, only has to go up enough to get the extractor through the gap between the rocker cover and strut tower. You don't have to undo the rack as well.
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    All sorted boys.. Thanks for the advice, I lifted the engine slightly and she slid straight in....
  1. [VIC] vn-vr turbo manifold - pacemaker comp extractors/3 inch exhuast/stock extractors
    By YILDI2 in forum Parts And Other Items For Sale
    Last Post: 25-08-2011, 01:40 PM
  2. [SA] 5L VN-VP extractors SWAP for VR/VS statesman extractors
    By DERTY in forum Swap / Wanted to Buy / Trade
    Last Post: 28-01-2011, 11:52 AM
  3. [SA] swap vl extractors for blue 202 extractors
    By leigh 7005 in forum Swap / Wanted to Buy / Trade
    Last Post: 01-06-2009, 09:34 PM
  4. Wildcat extractors Vs Pacemaker extractors.
    By rob_phill in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-06-2006, 09:05 PM
