Results 1 to 6 of 6
Thread: Dust boots front shocks
    spud_22's Avatar
    spud_22 is offline Ruled by the P
    95 VS Berlina
    Nov 2010
    Default Dust boots front shocks
    How hard is it to change the dust boots on the front shocks. Does anyone know roughly how much a set of new boots would cost.
    The shocks are pedders 8985 just wondering if these are any good. Cheers
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Usually they last the life of the shocks which can be the life of the car. If the boots on your Pedders shocks have failed then I'd go back to Pedders for comment as they should last the life of the shock. Be careful if you do decide to go back to them as they can be like used car salesmen and talk you into work you may not really want! To change you need to remove the spring struts, compress spring and disassemble..put new boot in and reassemble. May also need a wheel alignment.
    Cheapest part unless you are doing it yourself would be the boot. I'd use generic boots - the ones that fit steering racks - cost under $20 a pair. If you paid for labour I'd hazard a guess at $400 both sides for a normal mechanic.
    If you were real smart you may just be able to slit a boot lengthwise and slip it thru the coils when extended....that way it becomes pretty simple.
    Good Luck.
    Vs Statesman 5.0 - Vn 8plus
    Jan 2011
    ill fit them for a hundred + boots and another 50 for a x4 wheel alignemnt afterwards
    spud_22's Avatar
    95 VS Berlina
    Nov 2010
    i got the shocks 2nd hand so not keen on going to pedder. $150 sounds good. i have to wait till uni holidays tho. where abouts in VIC are you
    96 vs calais series 1
    Apr 2011
    maroochydore
    its simple the boot's are rubber and as with everthing in life they ware out. rubber becomes dry and cracks over time. i went to rotate my wheels the other day and when the wheel extended down to full travel the rubber boot broke apart. you can buy a product caller wruth rubber care. i use it on my vintage rc car's to stop tires from perishing.
    Jan 2011
    Quote Originally Posted by spud_22 View Post
    My workshop is just in dandenong mate pretty local
  1. vr front strut boots
    By python_hunter1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-04-2011, 12:26 PM
  2. vn front shocks
    By nudge701 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-04-2010, 09:46 PM
  3. vz front shocks gone
    By Archers in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 23-12-2009, 03:23 PM
  4. I need new front shocks, which are best?
    By dawg in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-09-2008, 02:20 PM
