Results 1 to 3 of 3
Thread: VS slouchy when cold
    VS Equipe
    Jan 2011
    Adelaide, SA
    Default VS slouchy when cold
    Hi Guys
    Since winter has hit I have noticed my ecotec has been rather sluggish in the mornings
    on a cold start it will idle fine but just doesn't seem to have much umph when I start driving (throttle almost feels heavier)...after 1-2km it comes right and goes hard.
    My brothers 350,000km L67 Calais doesn't seem to have this problem
    I am running Caltex GTX 20w50 oil if that makes any difference
    Is this normal behavior for an ecotec...it was fine through out summer its just these past couple of weeks
    96' VS Equipe (Current Project/Weekender) (CLICK HERE)
    Resident VR/VS Addict
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Possibly your auto transmission needs a service - once the oil warms up the clutches grip better etc. How long since it has been serviced?....should be done about every 3 years or 80K.
    vs commodore
    Oct 2009
    Tamworth NSW
    I agree with hako about the auto trans services,except Id halve that recommended service interval under normal driving conditions.You can also try a different thinner engine oil ,something like penrite HPR 15 ,which is a semi synthetic 15W -60 oil.Its a bit thinner when cold than the normal 20W-50 oil your using so it flows a bit easier when cold.Its fairly cheap too.Ive used this oil for a few years now with no problems,it also stays slightly thicker at high temps for better protection in the heat during the summertime...
  1. [QLD] Vp hard starting cold (and only cold)
    By channingvp in forum General
    Last Post: 27-08-2010, 12:39 AM
  2. keep it cold!!
    By `daj0pe in forum Projects
    Last Post: 03-01-2007, 11:10 PM
  3. climate control blowing cold aircon on cold days
    By stackner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2006, 03:24 PM
  4. Air con isn't cold enough VN
    By MyDunnyDoorIsRed in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-01-2006, 09:40 PM
  5. Cold Air For Vk
    By adsVN in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-04-2004, 05:38 PM
