+ Reply to Thread
Results 1 to 8 of 8
Thread: wheel bearing gone?
    walace Guest
    Default wheel bearing gone?
    just wondering what it cost to get wheel bearing done and what a mini spool does for the diff?
    hako is offline Donating Member hako Senator hako Senator hako Senator
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    walace Guest
    its in the rear end.. and whats a mini spool and anyway 2 make the diff a lsd with out changing it?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Do a GOOGLE search for 'mini spool' and all will be revealed. Re the bearing, the biggest cost will be labour as the bearings are usually under $20 each but the axle has to be pulled and the bearing pressed on/off etc.
    Mar 2004
    Patrio7's Avatar
    Patrio7 is offline 3Y3 K4N 5P33K 1337. Patrio7 Statesman
    '96 S1 VS Exec
    Jul 2005
    Perth, Como
    or a different way of explaining it
    a LSD will use little clutches to help stop one wheel spinning while the other does nothing [like say you turn and boot it the inside wheel will fry while the outside will do nothing, with LSD it'll stop them spinning independantly to a point.
    a mini spool is a straight lock of the diff. they are simpler than a LSD [no clutches] and dont wear out [as far as i know, stealthy, correct me here if applicable]
    the downside is that if you were goign to use your car on a circuit a lsd would allow a little wheel difference to occur [such as cornering where the difference is normal] a minispool will not allow this to happen so one or both of the wheels may skip or vibrate a little. once again i call on stealthy's experience.
    *bows down*
    oh wise spooler enlighten us! does hard acceleration around a corner [controled so as not to begin a slide or drift] cause any skipping or otherwise effects?
    attn Über geeks, i play Second life. Patrio Graysmark.
    CalaisVKiller Guest
    I thought minispools were illeagal. Basically they lock both so they spin together great for two wheel burnouts . But they are highly dangerous in high speed corners (taking them too fast) which is why they're probably illegal
    deathsminion's Avatar
    deathsminion is offline Chrgd,Coold,Twinthrot'in deathsminion has disabled reputation
    GT42R forced JZA80 Supra and VT Wagon
    Oct 2004
    Yep, illegal.
+ Reply to Thread
  1. Wheel Bearing Noise?
    By chromic in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-11-2007, 02:50 PM
  2. wheel bearing plz reply
    By TheStateo in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-07-2006, 11:08 AM
  3. Thrown a wheel bearing?
    By synoptica in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-01-2006, 06:25 PM
  4. wheel bearing access???
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-10-2005, 11:44 AM
  5. Wheel Bearing or Brake
    By Stretcher Bearer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-10-2005, 08:00 AM
