Results 1 to 10 of 10
Thread: ecotec running like arse, with pacemakers.
    VS3 S-pack M5
    Aug 2010
    Joondalup, WA
    Default ecotec running like arse, with pacemakers.
    Hey guys,
    I put some pacemakers on my VS ute ecotec not too long ago, and when i did that, i bought some new NTK lambda (oxygen) sensors, extended the wires accordingly and yea. now though, the car runs like Schitt, seems like its getting the wrong fuel/air mixture or something. i think the extractors have thrown the tune out on the car.
    One thing I've heard is that i could try putting resistors in the signal wire on the lambda sensor but this might not work. Does anyone know anything about this or had a similar experience?
    I've done a hard battery reset, but doesnt seem to be working.
    Cheers guys,
    Dave.
    Did have VS Berlina now have VT Berlina
    Mar 2010
    Cockatoo Vic
    ohh let me no what it is if you find out because i was just about to put some pacemakers and a red back on mine but i might hold off for a couple of weeks
    2004 XR6T & 1990 VN dragcar project
    Jan 2010
    Bendigo, Victoria
    Did you wire up the sensors wrong? Ie: some wires back to front?
    It has to be asked I'm afraid.
    vs commodore
    Oct 2009
    Tamworth NSW
    Fitting pacemakers alone wont cause it to run crook.Ive helped a couple of fellas fit their pacies,and theres never been any running problems afterwards,just better sound and better fuel economy...Id say it might have something to do with the oxygen sensors or the way youve fitted them up.Ive seen plenty of people have trouble with cheap s--t brand 02 sensors,now I always recommend only fitting genuine holden or delco/delphi brand oxygen sensors..Id also be going over everything and checking that you havent bumped or knocked off any wires or vacuum lines etc when fitting up the extractors..
    VS3 S-pack M5
    Aug 2010
    Joondalup, WA
    wires were lengthened by a reputable auto-sparky so i hope they are right haha. i sometimes get a engine light too so i will check the code if/when it comes on. will check over everything tomorrow when the sun is out.
    Jan 2010
    Bendigo, Victoria
    Quote Originally Posted by Brett_jjj View Post
    I agree. I've fitted quite a few pairs of these, as well as Hurricanes, and "advance" headers. None of them had these problems afterwards.
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    Quote Originally Posted by Dave93 View Post
    Did you rev it when starting again to reset the IAC ??
    http://woteva.tk/
    If it ain't broke... I can break it for you
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    if there new extractors then they will bugga ya o2's up for the first few thousand as they burn all the crap off the inside. Extractors just help extract the exhaust gases better so wont make anything worse. Sounds like the 02's are wired up wrong or there stuffed or you have the earthing issue. Ive never had luck with NTK in the vs's they come faulty out of the box sometimes, get either Bosch or Delphi nothing else. At the end of the day you really need a scantool on it to check there operation. Or laptop if you have the cables you can use Tunerpro to check out the crosscounts.
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    Quote Originally Posted by woteva View Post
    the IAC resets every time you turn the key to ON
  1. Running an ecotec on diesel?
    By Andrew426 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-10-2010, 11:16 AM
  2. Replies: 7
    Last Post: 01-02-2010, 03:23 PM
  3. Ecotec running rough 1300-1650rpm
    By Cursed CX8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-04-2008, 03:49 PM
  4. ecotec comp running sII vn
    By smokaharma in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-04-2008, 05:42 PM
  5. laughed my arse off
    By DRAGON7 in forum Jokes/Humour
    Last Post: 22-07-2004, 02:47 PM
