Results 1 to 9 of 9
Thread: which oil for my non lsd diff????
    95 VS SS 5L Commodore x chaser
    Feb 2011
    Roxby Downs
    Default which oil for my non lsd diff????
    hi im putting a single wheeler irs diff in my vs ss what is the right oil to put in it ???
    need help cheers
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Have a look in ur owners manual, has everything in that. I dont know off the top of my head.
    Reaper
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    castrol saf-xa is the recommendation for all commodores, but its way overpriced for diff oil.... just a normal 85-140 should do fine
    Feb 2011
    Roxby Downs
    Feb 2011
    Roxby Downs
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    I second the recommendation for Castrol SAF-XA. It may be a little higher priced than other oils, but its not like you change your diff oil every 5000kms, plus you normally need less than 2 litres I think. I did my diff about 6 months ago with it.
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    SYNSHIFT 75W/140 GL-5
    Service Refill Capacity: 1.7 Litres
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Holden Service Manual specifies:
    V6 engine without LSD - Castrol LSX90, Shell XD90LS or equivalent
    V6 engine with LSD and all V8s - Castrol SAF-XA, MOBILUBE SHC 80W-140 ID or equivalent.
    Sep 2007
    funny thing is, on the castrol lubeguide, it says to use the SAF-XA which is fully synthetic, yet the footnote 187 says only use synthetic when diff has a "high performance" tag. I think lsd oil in a non lsd is fine anyway, use just cant use non lsd oil in an lsd.
  1. [SA] WTB- 3.89 diff gears to suit borg warner diff
    By GTP 85 in forum Swap / Wanted to Buy / Trade
    Last Post: 31-05-2010, 01:23 AM
  2. 304 I need a new diff.. well I want a new diff..and mine's noisy..so..I need a new diff.
    By Warranty Void in forum V8 Development and Modification
    Last Post: 24-05-2010, 02:19 PM
  3. Changing vx diff do you have to unbolt the whole rear end or just the diff unit
    By H1GHROLLR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-11-2009, 06:35 PM
