Results 1 to 2 of 2
Thread: Trany
    vb sl
    Aug 2010
    mortlake
    Default Trany
    Hi my vs is having trouble much the same as on of the other posts iv read were it try's to kick back into 3rd gear and then back to 4th within a a few thenths of a second now I ran a diagnostic and did come up with a era but I mist some of it and when I tried to run it again it came up as 12 a pass should I f
    disconnect the battery for a few mins and try again will this reset every thing so I can run it again
    look at the bloke on your left now look at the bloke on you right now look at your self 2 out of the 3 people you just looked at are dead sh@ts which one are you
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Yes - disconnect the battery for 30 seconds, reconnect, then drive the car and do the code check again.
  1. my god!!! trany issue again!
    By maco_butterfly in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2008, 04:42 PM
  2. changing trany oil by syringe
    By andyli in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-05-2007, 02:56 PM
  3. leaky vy trany lines
    By justincase in forum General
    Last Post: 21-10-2006, 11:26 PM
  4. Dodgy VT Trany
    By Bigger-benny in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2005, 11:46 PM
  5. trany probs
    By paulhsv01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-04-2005, 12:11 AM
